Faster parts through local sourcing
  • Have your parts made locally or globally
  • Get CNC parts delivered directly from local machine shops
  • Guarantee consistent quality with the Hubs Standard
Upload your design for an instant quote
Hubs Local
We’ve expanded our network with local CNC machine shops in the US and Europe to offer you a reliable solution for faster part sourcing. Now, you can decide both where and when your parts are manufactured.
With Hubs Local, you can choose to order parts from specialized manufacturers within your custom-clearance borders and have parts sent directly to you from our local network. This means lead times as fast as five days and fewer shipping and compliance hurdles.
Access local machine shops near you
Hubs Local lets you source parts from our vetted local networks. Get custom components made locally or globally within the budget and timeframe that make the most sense for your project, all while supporting local manufacturers in your region.
All parts meet the Hubs Standard , guaranteeing consistent quality, every time. Make faster progress on your projects without having to compromise on design or quality.
Sourcing parts locally vs globally
With Hubs Local, you can get your custom parts from local shops as well as our global network of manufacturing partners. It’s your choice. There are benefits to local and global part sourcing, so get even more control of your supply chain by selecting the right mix.
Local
Global
Part Quality
Good (Hubs Standard™)
Capabilities
More narrow
Broad range
Time to parts in hand
Faster
Slower
Pricing
Higher
Lower
Shipping time
Shorter (low variance)
Longer (high variance)
What are the specifications for local sourcing?
Hubs Local is available for CNC orders shipped to the EU and US. To qualify for local sourcing, your order may need to meet certain specifications. You can find the details in your quote.
Explore the materials available for local sourcing in the EU and the US.
EU materials
Local sourcing is available for the following materials in the EU:
US order materials
Local sourcing is available for the following materials in the US:
bead blasting
Surface finishes
Get your locally-sourced CNC parts with the following surface finishes:
  • As machined
  • Smooth machining
  • Bead blasting
CNC machining near me: how to select local sourcing in the quote builder
To select local sourcing for your order and get parts machined in as fast as 5 days, choose Rapid lead time (5 business days) from the available options. You may be prompted to click on View requirements. This means that you need to change your order specs.
Curious about pricing for local sourcing? Upload your parts for a free, instant quote
Try out local sourcing in the quote builder
