3D printing service West Virginia
Our 3D printing techniques
With 90+ 3D printing shops in Protolabs Network (formerly Hubs), we produce high‑quality parts at competitive prices, from rapid Fused Deposition Modeling (FDM) prototypes to functional end parts made with Selective Laser Sintering (SLS) and Multi Jet Fusion (MJF).
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in West Virginia
SLS 3D Printing service in West Virginia
MJF 3D Printing service in West Virginia
SLA 3D Printing service in West Virginia
Our quote builder interface for instant 3D printing service online
Over 172 customers are satisfied with our 3D printing service.
“Great quality and *exceptionally* well packed. Would use again.”
Ben, Athens
Standard PLA, FDM
“Great help, item was printed quickly and good quality. ”
Ruevon, Bethel Park
Standard PLA, FDM
“The parts look great, and arrived faster than expected. I also really appreciated the test print and consulting he did for me on these parts.”
Andy, Lexington
Standard ABS, FDM
“This was my first experience in anything 3D printed, and I feel it turned out pretty great, so thank you!”
Josh, PITTSBURGH
Standard PLA, FDM
“Fantastic prints, really helped me a lot directly as well.”
Brayden, Pittsburgh
Fiberglass reinforced Nylon, FDM
“Professional, great communication, and top quality parts!”
Richard, Sewickley
Standard ABS, FDM
“Very prompt and communicated about the parts well. Gave me feedback to adjust the model so it would print better. Print quality was high and shipped quickly.”
Emily, Irwin
Standard PLA, FDM
“Great print quality and expertise. Thanks for the speedy service!”
Adam, Pittsburgh
Standard ABS, FDM
“I’m very happy with the service. My order arrived earlier than the estimated delivery date.”
Kentaro, Pittsburgh
Standard ABS, FDM
“Prints came out great, packaged well. Very happy. ”
Joe, Monroeville
Standard PLA, FDM
“Incredibly fast service, very high quality parts”
Adam, Youngstown
Standard PLA, FDM
“Received the parts a day early and they look good!”
Lillian, Indiana
Standard PLA, FDM
“Second order, no problems, good communication. Print as expected. Thanks.”
Daniel, Charlottesville
Standard TPU, FDM
“Print arrived in fantastic shape. Thank you!”
Lovieree, Columbus
Standard PLA, FDM
“Part was of good quality and received it in a timely manner.”
Matthew, Westerville
Standard resin, SLA/DLP
“Great communication to make sure my order was placed with the correct specs.”
Ryan, Columbus
Standard ASA, FDM
“Excellent experience. Even printed an extra piece for me beyond the ones requested.”
Ryan, GROVE CITY
Standard PLA, FDM
“OMG the print is uber amazing. looks perfect. thanks again for everything”
Alan, Columbus
Standard PLA, FDM
“Great service and quality. Very satisfied with the handling of our order! reliable, great communication and met our tough delivery requirement. ”
Richard, Wellington
Standard PLA, FDM
“Part turned out perfect. Could not be happier!”
Louie, Grafton
Standard PLA, FDM
“Quality of the parts is spectacular, and I was thoroughly impressed with the professional level and quality of packaging.”
Mikey, Lyndhurst
“Once again, beyond happy with the prints and the service.”
John, Brookville
“The printed part is great. The dimensions are accurate. The surface finish is better than I expected. Overall very good service.”
Junqi, Cleveland
Dental resin, SLA/DLP
“Great service, quick turn around time and knowledgeable hub.”
Nick, Altoona
Standard ABS, FDM
“Printed very quickly with little to no issues, post processing will go much easier.”
Joshua, Altoona
Standard PLA, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
