3D printing service Green Bay, WI
Our 3D printing techniques
With 90+ 3D printing shops in Protolabs Network (formerly Hubs), we produce high‑quality parts at competitive prices, from rapid Fused Deposition Modeling (FDM) prototypes to functional end parts made with Selective Laser Sintering (SLS) and Multi Jet Fusion (MJF).
FDM
Fast & affordable prototyping
See our FDM services
SLS
See our SLS printing services
MJF
See our MJF services
SLA
Visual prototyping
See our SLA services
FDM 3D Printing service in Green Bay, WI
SLS 3D Printing service in Green Bay, WI
MJF 3D Printing service in Green Bay, WI
SLA 3D Printing service in Green Bay, WI
Our quote builder interface for instant 3D printing service online
Over 154 customers are satisfied with our 3D printing service.
“This is my first time requesting any type of 3d printing. I will extremely pleased with the communication, speed of service and the print quality of my order and parts requested. Will definitely use this service again....when needed.”
Ryan, Oshkosh
Standard ABS, FDM
“Very helpful and fast! Also warns of possible errors before the print and gives helpful tips on how to improve part on your own.”
Kaden, mt. calvary
Standard PLA, FDM
“Very nice part. The bed side finish is very nice. I hope to order more parts soon. ”
Dean, New London
Standard PLA, FDM
“This was my first print, and while I'll improve on the modeling next time, the parts I ordered turned out exactly as modeled and ordered. Very happy with the communications (including the jpgs of the finished parts) and the overall turnaround.”
Keith, Glendale
Standard PLA, FDM
“Great communication. Good looking parts.”
Joseph, Milwaukee
Standard TPU, SLS
“Excellent service. I am new to the process and still learning. Thanks for the great experience. ”
John, Hartland
Standard PETG, FDM
“Great Experience, fast print and delivery, would work with anytime.”
Ryan, Milwaukee
Standard PLA, FDM
“Parts turned out great and were finished and arrived very quickly! Thank you! ”
Austin, Oconomowoc
Standard PLA, FDM
“There was a slight flaw in my design that resulted in a small ring around one edge of the print that wasn't suppose to be there. They took the extra time to tweak the STL so it would not print the ring. My print was just a simple little adapter piece and the cosmetics didn't matter to me but it was great they made the effort to maximize the quality of the print. I will definitely be using them again for future prints.”
Eric, Greenfield
Standard PLA, FDM
“Would be very pleased to work with this provider again.”
Adrian, South Milwaukee
Standard Nylon, SLS
“Very fast communication and very informative and considerate of my needs”
Hamilton, Wausau
Standard PLA, FDM
“Excellent production and service. Parts look outstanding. Looking forward to future business!”
james, FRANKFORT
Standard Nylon, SLS
“My order turned out perfect. Awesome service, awesome quality. ”
Ben, DeForest
Standard ASA, FDM
“Product is high quality and was completed very quickly”
Aaron, Kenosha
Standard resin, SLA/DLP
“Good communication and arrived in great condition ”
Sophia, Madison
Standard TPU, FDM
“Excellent quality print that arrived faster than expected.”
Carl, North Chicago
Standard ABS, FDM
“wow. the parts were way better than expected. Thanks!”
Eric, Grand Haven
Standard ABS, FDM
“Good communication, flexibility, and print quality. Well done. ”
Donald, spring lake
Standard PLA, FDM
“Parts are in printed to specifications and service was prompt and dependable. Thanks ”
Hugh, Crystal Lake
Standard ABS, FDM
“Very happy with the product and the service”
Israel, Highland Park
Standard PLA, FDM
“Great service. Quality product. Quick turn around. Well informed updates. No complaints.”
Jake, Traverse City
Standard PLA, FDM
“Quickly responded to questions and followed up well”
David, Northbrook
“Awesome. Really happy with my first 3D print”
Tim, Arlington Heights
Standard ABS, FDM
“Great! A lot of professional communication. Smooth process. Everything as expected. I would love to work with them again!”
Trent, Belvidere
Standard ABS, FDM
“I had a fairly large and complex order and everything was delivered as expected with great prints.”
Robert, Carpentersville
Standard PETG, FDM
See more
See more
Cosmetic standards
See more
3D printing materials
The 3D Printing Handbook
Buy the book from Amazon
FAQ's about 3D printing
