Online CNC machining service
On-demand CNC machining service for rapid prototyping and production parts, through a network of specialized, experienced and thoroughly vetted local and global CNC machine shops.
Get instant CNC machining quote All uploads are secure and confidentialThe easiest way to machine parts
From prototype to production volumes using one unified platform.
Get instant prices and lead times for more than 100 combinations of materials and finishes.
Quality & compliance
Quality documentation including COC, REACH, RoHS and material certificates. ISO 9001, AS9100, ISO 13485, ISO 14001 and ISO TS16949.
Access machine shops throughout our network of more than 250 vetted manufacturing partners.
Production volumes
Volume pricing for production quantities. Expertise in high-mix configurations requiring extensive customization.
CNC processes
- Tolerances down to ±.020 mm (±.001 in)
- Quality control and documentation
- Broad range of surface finishes
- Lead times from 5 business days
Produces parts by mounting a blank on a rotating chuck and removing material.
3 & 5 axis CNC milling
Creates complex geometries using 3 linear degrees of freedom: the X, Y, and Z axis.
Order specifications
Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T651 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6082-T651 | 3.2315 | 64430 | AlSi1MgMn Aluminum 6060 | 3.3206 | AlMgSi Aluminum 5052 | EN AW-5052 | 3.3523 | AlMg2,5 Aluminum 2017A | 3.1325 | 24530 | AlCu4MgSi Aluminum 2014 | 3.1255 | 24345 | AlCu4SiMg Aluminum 6063 | EN AW-6063 | 62400| AlMg0,7Si Aluminum 7050 | EN AW-7050 | 3.4144| AlZn6CuMgZr Aluminum 2024-T351 | 3.1355 | 24530 | AlCu4Mg1 Aluminum MIC6 Aluminum 7075-T6 | 3.4365 | 76528 | AlZn5,5MgCu Aluminum 5083-H111 | 3.3547 | 54300| AlMg4.5Mn0.7 Aluminum 6082 | 3.2315 | 64430| AlSi1MgMn Aluminum 6061-T6 | 3.3211| 65028| AlMg1SiCu
Stainless steel 416 | 1.4005 | X12CrS13 Stainless steel 15-5 | 1.4545 | X5CrNiCu15-5 Stainless steel 301 | 1.4310 | X10CrNi18-8 Stainless steel 430 | 1.4016 | X6Cr17 Stainless steel 440C | 1.4125 | X105CrMo17 Stainless steel 420 | 1.4028 | X30Cr13 Stainless steel 304/304L | 1.4301/1.4307 | X5CrNi18-10/X2CrNi18-9 Stainless steel 2205 Duplex | 1.4462 | 2205 | X2CrNiMoN 22-5-3 Stainless Steel 17-4 PH | 1.4542 | X5CrNiCuNb16-4 - Annealed state Stainless steel 303 | 1.4305 | X8CrNiS18-9 Stainless steel 316/316L | 1.4401/1.4404 | X5CrNiMo17-12-2/X2CrNiMo17-12-2
Mild steel S275JR | 1.0044 | Fe430B | IS2062 Mild Steel S235JR | 1.0038 | Fe 360 B Carbon steel C45 | 1.0503 | 1045 | EN8 Mild steel S355J2 | 1.0577 | 1522H | Fe 510 D Mild steel 1045 | 1.0503 | C45 | EN8 Mild steel A36 | 1.025 | Fe 410 Mild steel 1018 | 1.1147 | C18 |16Mn
Tool steel A3 - Annealed state Tool steel H13 | 1.2344 | X40CrMoV5-1 - Annealed state Tool steel S7 | 1.2355 | 50CrMoV13-15 - Annealed state Tool steel O1 | 1.2510 | 100MnCrW4 - Annealed state Tool steel A2 | 1.2363 | X100CrMoV5-1- Annealed state Tool steel D2 | 1.2379 | X153CrMoV12-1 - Annealed state
Invar 36
Acetal Copolymer (POM-C) FDA Acetal Copolymer (POM-C) ESD Acetal Copolymer (POM-C) Acetal Homopolymer (POM-H)
Nylon 6 Flame Retardant Nylon 6/6 30% Glass Filled Nylon 6 30% Glass Filled Nylon 6
PPSU | UL94 V-0
PTFE
PC
UHMW-PE HDPE
PP Homopolymer PP+GF(30%) PP
Garolite G-10
PEI Ultem 1000 PEI Ultem 2300 30% Glass Filled
Gallery of CNC machined parts
CNC machined prototypes and end-use parts produced through our network.
Get a quote in seconds
And receive your custom CNC machined parts in days.
Get instant CNC machining quoteOur distributed network
Specialized CNC machine shops around the world
CNC machining case studies
We’ve helped these innovative companies with custom CNC machined parts
FAQs
How do you guarantee the quality of my parts?
Your parts are made by experienced CNC machining shops within our network. All facilities are regularly audited to ensure they consistently meet our quality standards.
Protolabs Network is ISO-9001 certified and additional certifications are available through our manufacturing partners.
Find out more about our quality assurance measures.
Put your parts into production today
