What is bulk modulus? Understanding material compression in engineering
Need a material that can handle the pressure? Find out how bulk modulus shapes material performance.
Stainless Steel CNC Machined Part
When engineers need materials that won't buckle under pressure, bulk modulus is a predictive tool.
Imagine squeezing a tennis ball in your hand versus trying to compress a steel bearing. The tennis ball gives way easily, while the steel bearing hardly moves. This contrast in compressibility is what bulk modulus measures. For engineers, it’s a practical property that helps determine whether designs can withstand pressure without getting warped.
Bulk modulus quantifies a material’s resistance to uniform compression from all directions. Unlike other mechanical properties that focus on stretching, bending, or shear, bulk modulus tells you how much volume changes when pressure is applied equally on all sides. That makes a very important consideration in industries where components face high-pressure environments or need to remain dimensionally stable.
Understanding bulk modulus in material science
Bulk modulus is a measure of how hard it is to squeeze a material and change its volume. It’s determined by comparing the pressure you put on something to how much its volume shrinks. In other words, it shows how compressible (or incompressible) a material is. High values mean the material hardly compresses. Low values mean it squashes more easily under the same load.
For engineers, this matters because parts that look stiff at first might still compress under high pressure, which can lead to performance problems or even failures. Most metals have high bulk modulus values, while plastics and composites vary more, which is why choosing the right material depends on the demands of the application.
The bulk modulus formula and calculation
Understanding the math behind bulk modulus helps engineers turn theory into practical design choices. One common form of the formula is:
K = P / ε
  • K: Bulk modulus (Pa, MPa, or GPa).
  • P: Applied pressure.
  • ε: Volumetric strain (the fraction of volume change).
Volumetric strain is the change in volume divided by the original volume.  Another way to write the formula is K = –V (ΔP / ΔV), where V is the original volume, ΔP is the change in pressure applied evenly on all sides, and ΔV is the change in volume. The minus sign shows that when pressure goes up, volume goes down.
Both equations show the same thing: how resistant a material is to uniform (hydrostatic) pressure.
Engineers measure this by applying pressure from all directions and recording the volume change. In practice, this is done with hydrostatic pressure chambers or, more indirectly, with ultrasonic testing that uses wave speeds to calculate elastic constants.
Units are expressed in pascals (Pa), the SI unit of pressure equal to one newton per square meter. For practical engineering work, larger units are used: megapascals (MPa, one million pascals) and gigapascals (GPa, one billion pascals).
Example calculation
An aluminum component sees a uniform internal pressure of 50 MPa. Taking aluminum’s bulk modulus K ≈ 70 GPa (70,000 MPa), the volumetric strain is:
ε = P / K = 50 MPa / 70,000 MPa = 0.000714 (≈ 0.071% volume reduction).
Notice how tiny this volume change is at less than one-tenth of one percent even under substantial pressure. This shows why metals like aluminum are considered nearly incompressible for most engineering applications.
Note: This calculation assumes uniform (hydrostatic) loading within the elastic range, and actual K values vary by alloy and temperature.
Quick reference ranges
  • High bulk modulus (>100 GPa): Metals for structural and pressure applications
  • Medium bulk modulus (2-10 GPa): Engineering plastics for moderate pressure environments
  • Low bulk modulus (<2 GPa): Flexible materials, seals, and gaskets
Typical values range from ~1 GPa for flexible polymers to ~440 GPa for diamonds. To learn more about how properties like bulk modulus guide engineering, see the CNC machining knowledge base and our collection of articles on manufacturing materials
Bulk modulus vs. other elastic moduli
Now that we understand how to calculate bulk modulus, we can see how it compares to other material properties. Bulk modulus is one of three elastic constants used to describe stiffness. The other two are Young’s modulus and shear modulus.
Property What it measures Example application
Bulk modulus Resistance to uniform (volumetric) compression Hydraulic seals, pressure vessels, tanks
Young’s modulus Resistance to tensile stress (stretching) Bridges, cables, beams
Shear modulus Resistance to shear or torsional deformation Gears, shafts, fasteners
Engineers don’t look at bulk modulus in isolation. They consider it together with Young’s and shear modulus to get a full picture of how a material behaves. For tips on choosing the right mix of properties, see selecting the right CNC material
Why bulk modulus matters in material selection
Engineers use bulk modulus data to choose the right material for the job. It tells them how a part will behave under pressure and helps spot where things might go wrong.
  • Dimensional stability: Components that must maintain precise dimensions under varying pressures require materials with appropriate bulk modulus values. Too low, and the part will deform. Too high, and you may end up paying for more performance than you need.
  • System compatibility: In assemblies where multiple materials work together, mismatched bulk modulus values can create stress concentrations or unexpected load distributions. Engineers have to balance these properties across all system components.
  • Performance prediction: Understanding how much a material will compress under load allows engineers to design with appropriate tolerances and safety factors. This keeps designs efficient without risking failure.
  • Cost optimization: Materials with very high bulk modulus are usually more expensive. Engineers aim for the most cost‑effective option that still performs well.
  • Manufacturing impact: Stiff materials may need more force to form, while softer ones can be easier to shape but harder to machine precisely.
Industries where bulk modulus is critical
Several industries depend heavily on bulk modulus considerations for safe, effective designs. Choose a material that compresses too much under pressure, and hydraulic systems leak, parts no longer fit together, or components crack under load. That’s why bulk modulus is a key consideration in:
  • Oil and gas: Deep-sea drilling equipment and pipelines face enormous pressures that require materials with predictable bulk modulus behavior.
  • Marine engineering: Submarine hulls and deep-sea equipment represent the most demanding bulk modulus applications due to extreme water pressure at depth.
Materials available through Protolabs Network
Protolabs Network provides a wide catalog of materials with reliable bulk modulus data, helping engineers select options for pressure-critical projects. Here is a condensed overview of the common categories.
Technology Material category / material Bulk modulus (GPa) Typical applications Key notes
CNC machining metals Steel 160–180 Structural, machinery Common and strong
CNC machining metals Aluminum alloys 70–76 Aerospace, automotive High strength-to-weight
CNC machining metals Titanium alloys 100–110 Medical, aerospace Biocompatible, corrosion resistant
CNC machining metals Copper 130–140 Conductive components Excellent conductivity
CNC machining plastics ABS 1.5–2.0 Automotive, consumer Versatile engineering plastic
CNC machining plastics Nylon 2.0–3.0 Gears, bushings Tough, chemical resistant
CNC machining plastics Polycarbonate ~2.4 Optical, safety Transparent, impact resistant
CNC machining plastics Acrylic (PMMA) 2.0–3.0 Displays, optical components Optical clarity
CNC machining plastics Polypropylene 1.1–1.6 Chemical processing Lightweight, flexible
3D printing plastics PLA 2.0–3.0 General prototyping Easy to print, biodegradable
3D printing plastics Nylon 2.0–3.0 Functional end-use parts Tough and wear-resistant
3D printing plastics ABS 1.5–2.0 Prototypes, functional parts Durable, common material
3D printing plastics PETG 2.0–2.5 Durable prototypes Good balance of toughness and printability
3D printing plastics TPU 1.0–1.5 Flexible parts High elasticity
Injection molding plastics ABS, Polycarbonate, POM, PEEK, PP, PVC ~1.5–2.5 Automotive, medical, packaging High-volume production capability
Sheet metal materials Aluminum 5052 70 Moderate-strength enclosures Good formability
Sheet metal materials Stainless steel 304 160–180 Structural panels Corrosion resistant
Sheet metal materials Copper C110 130–140 Electrical applications Excellent conductivity
Ceramics (custom options) Aluminum oxide 250–280 High-wear parts Very brittle, extreme hardness
Bulk modulus values are approximate. They vary with grade, additives, and processing method (for example, bar stock vs. filament vs. molded parts). Download our data sheets for exact numbers.
For precision applications, you can also choose specialized or custom materials through our CNC machining, injection molding, and 3D printing services. Need a material that’s not on the list? We have hundreds more available by request. Just send your requirements to network-sales@protolabs.com.
Advancing your materials knowledge
Understanding bulk modulus represents just one aspect of comprehensive materials engineering. Our material guides help engineers incorporate bulk modulus considerations into their design processes.
Key resources:
Get started with your next project
Need a material that holds up under pressure? Upload your CAD file to get a free, instant quote.
What’s the difference between bulk modulus and Young’s modulus?
Young’s modulus measures resistance to stretching, while bulk modulus measures resistance to uniform compression. Both are used in material selection.
How does temperature affect bulk modulus?
Bulk modulus generally goes down as temperatures go up. For an overview of materials that remain stable at higher temperatures, check out our heat-resistant plastics guide
What’s the relationship between bulk modulus and compressibility?
Bulk modulus and compressibility are inverses. High bulk modulus = low compressibility.
Is bulk modulus the same as volume elasticity?
Yes, volume elasticity is another term for bulk modulus.
What’s the bulk modulus of water?
Water has a bulk modulus of ~2.1 GPa. Even under the extreme pressures found at the deepest parts of the ocean (about 100 MPa), water compresses by less than 5%. This resistance to compression is why engineers usually treat liquids as incompressible in most calculations.
How does bulk modulus relate to atomic structure?
Materials with strong atomic bonding and dense packing typically have higher bulk modulus values, which provides insight into alloy design, since adjusting atomic arrangement and bond strength can impact compressibility.
UL 94 classification in materials: A guide to flame retardant plastics
Gas Welding
Bevels: Machines and services for metal edge preparation
Counterbore versus countersink: key differences for engineers
Material ductility
Understanding shear stress and shear load
What are countersinking holes and how do you use them?
Understanding tapped vs. rolled threads
Rz vs Ra roughness
Certifications mockup for the knowledge base article
Different types of quality documentation and when you need them
Discover the flame retardant plastics we work with. These meet the claims in the UL 94 classification in materials. Upload your CAD file.
Gas Welding
Bevels explained: We help you to improve weld quality and structural integrity. Discover the best machines and get instant DfM feedback on your CAD.
Counterbore versus countersink: These are the key differences for engineers. Read about the differences between these hole finishing methods.
Material ductility
Learn what ductility means, how it affects material deformation, and why it matters when selecting materials and designing reliable parts.
Learn how shear stress affects your designs. Get practical formulas, material guidelines, and manufacturing tips to prevent shear failures in bolts, joints, and components.
Bulk modulus measures material resistance to compression. Find out the formulas and why engineers use it for material selection in aerospace, automotive and more.
Countersinking holes are conical holes designed to seat the head of a screw, bolt, or fastener so it sits flush with or just below the surface. This keeps the part’s outer layer smooth, which can improve its appearance, safety and performance. In this guide, we’ll drill into the ins and outs of countersinking, covering methods, applications, pros and cons, and tips for getting it just right.
What are tapped and rolled threads, and what do engineers need to know about them to manufacture high-performance parts? Find out here.
Rz vs Ra roughness
Learn about the role quality documentation plays in the manufacturing process, how to obtain it, and the types of documentation that apply to parts, materials, and more
