Understanding shear stress and shear load
Learn how shear stress affects your designs. Get practical formulas, material guidelines, and manufacturing tips to prevent shear failures in bolts, joints, and components.
When one part of a component tries to slide past another, that's shear stress at work. In this article, we cut through the complexity to show what it is, how to calculate it, and how to design parts that stand strong under shear.
Introduction to shear stress and shear load
Shear is one of the three basic types of mechanical stress, but it often gets less attention than tension and compression. Understanding it is essential because many real-world failures happen due to shear.
Shear Load (or Shear Force)
The external force applied tangentially (parallel) to a surface, creating a tendency for layers to slide past each other. Think of pushing a block of wood with opposing forces—one up and one down—so it slides along a plane. Shear load is measured in Newtons (N) or pounds (lbf).
Shear Stress
The internal resistance within the material that opposes sliding, defined per unit area. Picture pushing one sheet of paper across another—your hand applies the load, the paper resists through shear stress.
In short, shear load is the outside force, shear stress is the inside resistance, and failure happens when stress exceeds what the material can handle.
Shear strength ranges
Shear resistance Strength range (psi)
Excellent 40,000+
Good 20,000–40,000
Moderate 5,000–20,000
Limited 1,000–5,000
Poor < 1,000
Why shear stress and shear load matter
Everyday parts like bolts, beams, and adhesives are under constant shear forces. These forces often govern whether a design holds or fails, even when tension and compression seem safe. In fact, many failures blamed on tension or compression start with shear. The scary part is that shear failures often happen suddenly, without much warning.
When shear dominates your design
  • Bolts, pins, and fasteners (load across diameter)
  • Short, thick sections under load
  • Adhesive and welded joints
  • Keys, splines, and rotating connections
  • Punched or stamped edges in sheet metal
Shear stress basics and formulas
To work with shear in design, you need the basics of how it’s calculated. The good news is the formulas are straightforward and widely used.
τ = F/A
Where τ = shear stress, F = shear force, and A = area resisting shear.
Example: A 1/4" steel pin carrying 2,000 lbf has an area of 0.049 in², so shear stress = 40,800 psi. Since steel handles ~40,000–60,000 psi, the pin is at its limit.
For torsion on shafts:
τ_max = Tr/J
Where T = torque, r = radius, J = polar moment of inertia.
Example: A 1" shaft under 500 lb-in torque sees ~2,550 psi shear stress—well within limits.
Understanding how materials respond to different types of stress helps you predict failure modes. For a deeper dive into how stress and strain relate across different loading conditions, see our guide on material stress vs. strain
Shear vs. tensile vs. compressive stress
To put shear into context, it helps to compare it with the other two basic stresses:
  • Tensile stress: Pulling loads, like cables and rods.
  • Compressive stress: Squashing loads, like columns.
  • Shear stress: Sliding loads, like bolts and welds.
Metals usually show shear strengths around 50–80% of their tensile strength. This means a steel that can handle 60,000 psi in tension might only handle 40,000 psi in shear.
Even when tension or compression seems to dominate your design, shear may actually control failure. A bolt holding two plates together is a good example. It looks like it's under tension, but it's actually loaded in shear across its diameter.
Material behavior in shear
Understanding how different materials behave in shear can help you predict how they’ll fail. Some stretch and bend before breaking, while others snap suddenly.
Ductile materials
  • Behavior: Can bend and stretch before breaking, giving warning before failure.
  • Examples: Steels and most metals
  • Yield shear strength: ~150–300 MPa
  • Ultimate shear strength: ~200–600 MPa
Brittle materials
  • Behavior: Break suddenly with little warning.
  • Examples: Ceramics, some plastics
  • Ultimate shear strength: often <100 MPa
Fiber composites
  • Behavior: Performance depends heavily on fiber orientation and matrix.
  • Examples: CFRP, GFRP
  • Typical shear strength: 40–120 MPa
Design examples under shear
Real components carry loads in specific ways. These examples show where shear forces matter most:
  • Bolts and pins: The pin resists sliding across its width. In single-shear joints, load is carried across one plane. In double-shear joints (supported on both sides), the load is carried across two planes, nearly doubling capacity.
  • Lap joints: Welded, glued, or fastened overlaps transfer load through shear. Longer or thicker joints hold more, and engineers often prefer double-lap joints over single-lap joints to balance load and reduce bending.
  • Keys and keyways: Stop shafts and hubs from spinning apart by sharing torque through shear faces.
  • Adhesives: Work best in shear. Avoid peel loads whenever possible.
  • Sheet metal tabs: Edges carry shear load. Clean cuts and good thickness improve strength.
Testing shear strength
Testing shear strength gives reliable numbers instead of estimates. Standardized methods make it easy to compare results across materials and designs.
  • Lap-shear test: Two flat pieces of material are overlapped and bonded, then pulled apart until the joint fails. This is commonly used for adhesives and welds to measure how well the joint resists sliding.
  • Punch shear test: A punch tool presses through a sheet until it shears out a slug of material. This simulates how sheet metals fail in punching or stamping operations.
  • Torsion test: A cylindrical piece (like a shaft or rod) is clamped and twisted until it fails. This shows how materials behave in shear under rotational loads.
Manufacturing considerations
How a part is made can change its ability to resist shear. Surface finish, defects, and microstructure all play a role.
Choosing materials and finishes
Select the right material and finish to improve shear strength without overcomplicating design:
Material comparison for shear applications
Material Ultimate tensile strength (MPa) Typical shear strength (MPa) Shear/Tensile ratio Key benefits Best applications
Mild steel (A36) 400–550 250–350 ~0.6 Low cost, easy to machine, ductile Structural beams, bolts, general construction
Aluminum 6061-T6 290 180 ~0.62 Lightweight, corrosion resistant Aerospace parts, automotive components, frames
Aluminum 7075-T6 570 330 ~0.58 High strength-to-weight ratio Aircraft fittings, high-performance applications
Stainless steel 304 500–750 300–450 ~0.6 Corrosion resistant, strong Food processing, marine hardware, fasteners
Nylon (unfilled) 70 40 ~0.57 Tough, flexible, wear-resistant Gears, bearings, snap-fit joints
Polycarbonate 65 35 ~0.54 Impact resistant, transparent Safety equipment, lenses, protective housings
Epoxy adhesive (cured) 60–80 25–40 ~0.45–0.5 Strong bonding, versatile Adhesive joints, composite bonding
Cost and design tips
Good shear design doesn't always come with high costs. Small changes make big differences:
  • Add thickness or overlap instead of using pricier materials.
  • Use standard rated bolts and pins.
  • Avoid unnecessary tight tolerances. Shear isn't highly sensitive to small variations.
  • Favor double-shear designs for nearly double strength.
How Protolabs Network can help
Getting shear-critical parts right is all about designing smart from the start. Protolabs Network manufactures thousands of parts every day, which means we’ve seen where designs tend to fail in shear—and how to prevent it.
Our automated quote builder gives you instant DFM feedback on potential weak points, so you can spot issues before production. If you have specific questions or complex needs, our engineers are on hand to guide you further.
Need to manufacture a part that performs reliably under shear loads? Get an instant quote and see automatic DFM feedback in minutes.
How can I tell if my design fails in shear instead of tension?
Calculate both stresses and compare to material properties. Shear often controls in joints and thick parts.
Why is my bolt breaking when rated for the load?
Check if it's in shear—ratings are ~60–70% of tensile ratings.
Should I use the same safety factor for shear and tension?
Usually yes, but shear failures give less warning.
Does surface finish affect shear?
Yes. Smoother surfaces resist cracks better under repeated loading.
Why do 3D printed parts split along layers?
Layer adhesion is weaker than bulk material. Orient layers so shear planes align with layer boundaries.
manufacturing SLS1
Stress strain diagram: How materials behave under load
sheet metal shearing
Shear Modulus: Definition, formulae, and material values
UL 94 classification in materials: A guide to flame retardant plastics
Gas Welding
Bevels: Machines and services for metal edge preparation
Counterbore versus countersink: key differences for engineers
Material ductility
Stainless Steel CNC Machined Part
What is bulk modulus? Understanding material compression in engineering
manufacturing SLS1
Understand stress–strain diagrams and material failure under load. Work on your design and upload your CAD file for expert feedback.
Compare G values for steel, aluminum, and polymers, and see how torsion testing ensures part integrity. Upload your CAD-file easily.
Discover the flame retardant plastics we work with. These meet the claims in the UL 94 classification in materials. Upload your CAD file.
Gas Welding
Bevels explained: We help you to improve weld quality and structural integrity. Discover the best machines and get instant DfM feedback on your CAD.
Counterbore versus countersink: These are the key differences for engineers. Read about the differences between these hole finishing methods.
Material ductility
Learn what ductility means, how it affects material deformation, and why it matters when selecting materials and designing reliable parts.
Bulk modulus measures material resistance to compression. Find out the formulas and why engineers use it for material selection in aerospace, automotive and more.
