Precision CNC machining for aerospace applications
Precision CNC machining delivers the tight tolerances, lightweight materials, and custom solutions that aerospace manufacturers need to get their ideas airborne.
Plane above clouds
From launching satellites and manufacturing autonomous aircraft to fine-tuning flight systems, aerospace teams need parts that perform without compromise. CNC machining powers ideas that are ready for takeoff.
Why use CNC machining for aerospace-grade components?
CNC machining is used by engineers across the globe to produce high-performance aerospace parts because it combines precision, repeatability, and material versatility. In aerospace manufacturing, every micron counts. Whether it's landing gear that withstands dynamic loads, a turbine housing that needs thermal stability, or a UAV bracket that’s got to be featherlight and structurally sound, CNC machining provides the dimensional accuracy and surface finish required in mission-critical applications.
Aerospace components are typically produced in low to medium volumes but demand exceptionally high tolerances and consistent performance. CNC machining bridges this gap, allowing engineers to iterate quickly, qualify parts faster, and scale production while maintaining high part quality.
Here’s why CNC machining is a top choice across key aerospace components:
Extreme precision: Aerospace parts often require tolerances within microns. CNC machining delivers this level of detail with repeatability, which is critical for components like control arms, gear assemblies, and sensor housings.
Material flexibility: From titanium and stainless steel to high-performance aluminum alloys, there are a wide range of metals and plastics that can be CNC machined.
Design complexity: With multi-axis CNC capabilities, complex geometries such as airfoil profiles, mounting features, and pocketed designs can be accurately milled without needing too many changes to the setup.
Tight surface and dimensional control: Surface finishes like roughness average (Ra) less than 1.6 μm and uniform dimensional characteristics are required for effective fluid systems and structural joinery.
Production versatility: Whether it's a one-off prototype, a flight-ready part, or spares for maintenance and repair, CNC machining offers engineers a lot of flexibility.
Check out more CNC aerospace design tips and benefits in this quick video overview
What makes CNC machining aerospace-grade?
Not all CNC machining is created equal. Aerospace-grade CNC manufacturing must meet strict requirements for safety, performance, and quality control. This includes:
  • Certification to AS9100, the leading quality standard for aerospace manufacturing
  • Material traceability from raw stock to finished part
  • Detailed documentation and inspection reports
Protolabs Network is certified to AS9100, and many of our manufacturing partners are too, ensuring high standards for documentation, traceability, and quality assurance
What types of aerospace parts can be CNC machined?
Aerospace manufacturers rely on a variety of technologies to build flight-ready parts, and the right process often depends on the part’s geometry, material, performance requirements, and production volume. While some parts, like internal panels or brackets with complex internal channels, may be better suited to injection molding or additive manufacturing, others are a clear match for CNC machining due to the precision, strength, and repeatability it offers. Below are examples of components where CNC is typically the best-fit solution
Engine components: These parts face high heat and pressure, so they’re usually made from strong metals like titanium or stainless steel. CNC machining delivers the precision needed to keep them working reliably.
Airframe brackets and structural parts: These need to be light but strong, often with tricky shapes. Five-axis CNC milling helps shape them accurately while reducing stress points.
Landing gear and control system parts: Because these parts take a beating from constant motion and stress, they need strong materials and extremely tight tolerances. CNC delivers both.
Custom housings and enclosures: Since these parts often hold sensors or electronics, everything needs to line up exactly, which CNC machining can achieve with repeatable accuracy.
Satellite and UAV components: These applications need to be lightweight and perform under extreme conditions. CNC machining gives engineers the control to fine-tune every cut and contour.
Learn more about how our aerospace manufacturing services support complex geometries, lightweight structures, and high-performance alloys.
024-001 CNCmachining ep3
Benefits of on-demand CNC machining for aerospace
On-demand CNC machining is changing how aerospace teams bring parts to life. Instead of waiting weeks for quotes or tooling, engineers can quickly prototype, test, and revise designs in real time. This flexibility is especially valuable in aerospace development, where innovation is fast-paced, requirements can shift quickly, and every component must meet exacting standards. Key benefits of on-demand CNC machining include:
  • Faster design iteration: Engineers can test and revise parts quickly without the delays of traditional tooling and setup.
  • Shorter lead times: Get production-ready parts in days, not weeks, which is great for fast-moving projects or last-minute fixes.
  • Low-volume flexibility: Order only what you need, when you need it, without high minimum order quantities.
  • Easy prototyping-to-production transition: You can easily shift from prototype to pilot runs using the same manufacturing model.
  • Dynamic supply chain support: Fill gaps or manage spikes in demand without adding overhead.
  • Accessible quoting and sourcing: Tap into instant pricing, DFM feedback, and sourcing from a global partner network.
This agile approach is ideal for aerospace applications like drone development, flight system testing, and mission-critical part replacement. Engineers can move faster without compromising on quality or control.
Protolabs Network supports this model with access to a global network of AS9100-certified manufacturing partners—so you get the speed of on-demand production along with aerospace-grade reliability. You also benefit from full IP protection, instant quoting, and a network with near-limitless capacity to support prototyping, validation, and production at scale.
Watch this video on our CNC machining services to see how our global network supports aerospace production.
CNC aerospace parts in action
Here are just a few examples of how aerospace companies are using CNC machining to get their ideas off the ground:
Ampyx Power case study
CNC machining was used to produce lightweight, precision aluminum parts for the company's airborne wind energy system prototype.
Space Tango case study
CNC-machined components helped build modular research platforms designed to operate in microgravity aboard the ISS.
Kepler satellite case study
Kepler leveraged CNC machining to accelerate development of a satellite chassis from prototype to space-ready hardware, turning around parts within a single week.
What are the best materials for aerospace CNC machining?
Choosing the right CNC material can make a big difference in how well a part holds up under stress, heat, and vibration. The best material depends on the job—some need to handle high temps, while others need to be lightweight and corrosion resistant. Here's a quick look at the most commonly used materials, grouped by type:
Additional materials and surface finishes may be available depending on your requirements. You can contact networksales@protolabs.com to discuss the options.
What are the best surface finishes for aerospace CNC machining?
Surface finish selection is just as critical as material choice. The right finish can protect against corrosion, improve performance, and meet regulatory or aesthetic requirements.
When choosing a finish, consider:
  • Material compatibility: Some finishes work only with metals (e.g., anodizing for aluminum).
  • Application requirements: Parts exposed to corrosion or chemical environments benefit from coatings.
  • Regulatory standards: Aerospace parts may require traceable finishing processes.
Below is a comparison of common finishes.
Surface finish Benefit Common materials Applications
As-machined No additional finish, tolerances held to machining spec All CNC-compatible metals, plastics Prototypes, internal brackets, tight-tolerance parts
Bead blasting Creates a uniform matte texture and removes minor imperfections Aluminum, Titanium, Steel Mounts, housings, cosmetic panels
Polishing Smooths surfaces for better aerodynamics or aesthetic finish Titanium, Stainless Steel Exterior casings, fluid-flow components
Anodizing Corrosion resistance, wear resistance, and color coding for aluminum Aluminum 6061, 7075, 2024, Titanium UAV structures, housings, external brackets
Anodizing Type III Harder, more wear-resistant coating than Type II for aluminum Aluminum 6061, 7050, 7075 Structural parts, brackets
Chromate conversion coating Adds corrosion resistance for aluminum/magnesium parts without affecting conductivity Aluminum alloys Electrical housings, structural frames
Electroless Nickel Plating Corrosion resistance, wear resistance, and uniform thickness Aluminum, Steel, Inconel 718 Gears, housings, electronic components
Black Oxide Mild corrosion resistance, reduced light reflection Steel Tooling, aerospace fixtures
Brushing + Electropolishing Smooth, clean finish with reduced contaminants Stainless steel Medical and aerospace fasteners
CNC design tips for aerospace parts
Well-designed parts reduce production time, extend part life, and increase safety in critical aerospace environments. Aerospace engineers face unique constraints—including extreme temperature ranges, vibration, and weight limits—which require careful planning from the earliest stages of part design.
  • Keep it light (but strong): Use pockets, cutouts, and internal channels to reduce weight—just be careful not to compromise strength or increase vibration.
  • Make sure everything is accessible: Design your parts to be as easy to machine as possible. Avoid tricky shapes like deep, narrow cavities that require complex setups.
  • Stick to standard hole sizes: Using consistent fastener sizes and interface points makes parts easier to assemble and swap out.
  • Use rounded internal corners: This reduces tool wear, speeds up machining, and avoids weak points in the design.
  • Tolerance with intention: Only use tight tolerances where absolutely necessary. Over-specifying can make parts harder (and more expensive) to machine.
  • Think about temperature changes: Materials expand and contract with altitude and heat. Design parts to handle that without warping or failing.
  • Keep wall thickness consistent: This helps prevent distortion and improves structural strength.
Get more insights from our collection of articles about designing for CNC machining
Alternatives to CNC machining in aerospace manufacturing
While CNC machining is essential for high-precision aerospace parts, it’s not the only game in town. Other manufacturing technologies offer advantages depending on part geometry, material, and volume.
Many aerospace teams combine technologies to get the best results—such as 3D printing a complex form and CNC machining it for final fit and precision. Choosing the right process depends on performance goals, production speed, and budget.
Where to learn more about CNC machining
Explore our Knowledge Base for in-depth CNC resources, or browse our latest case studies for real-world examples.
Ready to manufacture your next aerospace part? Upload your CAD file for instant pricing and DFM feedback.
Have a custom request or certification requirement? We can certify to AS 9100 D/ ISO 9001:2015. Contact your account manager or networksales@protolabs.com to learn more.
CNC machining for small parts
Acrylic CNC Machining Process
A guide to acrylic CNC machining
CNC lathe machine in action.
CNC turning machines: How they work and when to use them in manufacturing
Plane above clouds
What is CNC machining best for? How engineers use it in practice
5 axis cnc milling machine
What is CNC milling?
Learn how to design and manufacture CNC small parts with tight tolerances, the right materials, and reliable DFM practices.
Discover everything about acrylic CNC machining: material grades, design guidelines, surface finishes, applications, and cost factors for precision PMMA parts.
Learn how CNC turning machines work, their applications, and when to choose turning vs. milling. Complete engineering guide for cylindrical parts
Plane above clouds
Need a part that fits right, performs reliably, and doesn’t take weeks to produce? CNC machining makes it happen. Engineers count on it for its tight tolerances, wide material compatibility, and fast turnarounds—no tooling required. Whether you’re prototyping or scaling up with production orders, CNC machining gives you full control over geometry, functionality, and surface finish.
What is Delrin and why is it unique? Delrin, or POM-H (homopolymer acetal), is a semi crystalline engineering thermoplastic used for CNC machining, 3D printing, and injection molding to produce durable, precision components. This article examines Delrin’s key properties and guidance for getting the most from the material.
CNC milling is a subtractive manufacturing process used by engineers to source precision parts through outsourced CNC machining. This article explains how CNC milling machines work, what kinds of parts can be produced with milling, and design guidelines that help optimize parts for manufacturability.
How do you prepare technical drawings for CNC machining and why are they important? Technical drawings are standard documents used in manufacturing to communicate technical requirements between the designer, engineering team, and the manufacturer. Clear drawings reduce ambiguity, speed up production, and help ensure parts are produced to the required specifications.
What is CNC machining and how does it work? This overview explains the basic principles and fundamental mechanics, along with the key benefits and limitations, of this subtractive manufacturing process.
