Brittleness in materials: design tips for reliable parts
Brittle failures can turn a well-designed part into a liability. Find out how to select materials and design features that prevent sudden, catastrophic cracks.
Material Brittleness Metal
Learn how to choose materials and design features so your custom parts won't crack when it counts.
Engineers designing safety-critical components know the worst cracks are the ones you don't see coming. Brittleness describes a material’s tendency to fracture suddenly under stress with little plastic deformation, rather than bending first. That makes brittle materials a bigger risk when cracks are hard to spot or failure needs to be predictable.
In this guide, we'll cover what brittleness means in engineering, what increases it, how it's measured, and practical design and manufacturing steps that help prevent the bitter cost of brittle failure.
What brittleness means in engineering
For engineers, brittleness shows up as low toughness and low tolerance for flaws. A part can stay rigid under load until a small crack—often starting at a notch, hole, or sharp corner—grows quickly and the part snaps.
Instead of bending or giving visual cues, brittle materials crack and break cleanly. Think of bending a paperclip (ductile) versus snapping chalk (brittle).
Brittle vs. ductile
Behavior Brittle materials Ductile materials
What you see first Sudden failure with little warning Gradual deformation before failure
Energy absorbed before failure Low High
Typical fracture surface Clean and flat Rough and stretched/deformed
Common examples Glass, ceramics, cast iron Aluminum, copper, many steels
For more on material behavior, see understanding material stress vs. strain.
Why brittleness matters in design
​Brittle failures happen without warning. In safety-critical parts, that can be catastrophic. Even in everyday products, brittle cracking drives scrap and warranty issues.
The tricky part is that brittle materials are often notch-sensitive, so small features like holes, threads, tight radii, or a scratch can become crack starters. Risk also increases under impact loading and at low temperatures, when toughness can drop fast. That’s why brittle-prone designs usually need smoother geometry, better surface control, and more validation than a similar ductile part.
Factors that increase brittleness
Even if a datasheet says a material is “brittle” or “not brittle,” how brittle your actual part behaves depends on context. Many materials become more brittle, or more crack-prone, depending on conditions, geometry, and surface quality.
  • Strain rate: A part that bends under a slow load may crack under impact.
  • Microstructure: Grain size, heat treatment, and internal defects can increase crack risk.
  • Environment: Corrosion, hydrogen exposure, and stress-corrosion can embrittle materials over time.
How brittleness is measured
There isn’t one single “brittleness number.” Engineers usually estimate brittle-failure risk by looking at toughness (how well a material resists cracking) and ductility (how much it can deform before it breaks), using standardized tests.
  • Impact testing (Charpy and Izod): Measures how much energy a notched sample absorbs before it fractures in a fast strike. Lower energy usually means a higher risk of brittle failure, especially under impact or at low temperatures.
  • Fracture toughness (K_IC or K_c): Measures how hard it is for an existing crack to grow, usually reported in MPa·√m. K_IC is the stricter plane-strain value. K_c is used when those conditions aren’t met. Higher values mean cracks spread less easily, which helps when small flaws are unavoidable.
  • Tensile test metrics: Elongation (percent increase in length) and reduction of area (percent decrease in cross-section) are quick indicators of ductility. Lower values usually mean less stretching before fracture (more brittle in tension).
Test What it measures What can suggest brittleness What to look for
Charpy/Izod impact Energy absorption on impact <20 J typical Test at service temperature, watch for a sharp drop in the cold.
Fracture toughness (K_IC or K_c) Crack propagation resistance (MPa·√m) <20 MPa√m typical Best when flaws are expected, helps predict whether a crack will propagate.
Tensile elongation Plastic deformation before failure <5% typical Single digits are a red flag, compare the same standard and gauge length.
Reduction of area Cross-sectional narrowing (necking) at fracture <10% typical Use with elongation, low plus low usually means limited ductility.
*There isn’t a universal “brittle” cutoff for these tests. Compare like-for-like data (same standard, specimen geometry/thickness, temperature, and processing condition), and prioritize test results at your part’s service temperature.
For more information, check our collection of articles on manufacturing standards and technical data.
Design tips to prevent brittle failure
Good part design can reduce brittle failure risk, even when you’re using materials that have some brittleness. The goal is to lower stress concentrations, limit shock loads, and make cracks easier to catch before they become a real problem.
  • Minimize stress concentrations: Add fillets, ease section changes, and keep holes/cutouts out of high-stress zones. A 3 mm inside radius is a common starting point.
  • Manage impact and shock: Avoid long cantilevers, spread loads, and add ribs or local thickness where needed.
  • Control assembly loads: Set torque and fits, and be careful with press and interference fits.
  • Design for temperature: Check cold performance, and increase safety factors if toughness drops.
  • Plan for inspection: Keep critical areas accessible, especially notches, holes, and threads.
  • Add redundancy when needed: Use multiple load paths for safety-critical designs.
Understanding different load types helps too. Learn more about shear stress and shear load to design joints that work with your material's properties.
Material selection guidelines
Material choice is your first line of defense against brittle failure. Start with the failure mode you can’t live with, then pick materials (and design margins) that steer you away from it.
Material selection decision table
If your part has… Prioritize… Materials to consider Watch out for…
Safety-critical failure modes Toughness, ductility, crack tolerance (K_IC or K_c) Stainless steel 304/316, aluminum 6061/7075 Notch sensitivity, small flaws you can’t fully avoid
Impact or shock loading Impact strength (Charpy/Izod), ductility Polycarbonate, ABS, Nylon Room-temp data that hides cold-weather brittleness
Lots of holes, threads, tight radii Toughness, ductility, surface-finish tolerance Aluminum, Nylon, stainless steel Sharp transitions and machining marks that start cracks
Corrosive or hydrogen risk Environmental resistance, stable toughness over time Stainless steel 316 Stress-corrosion cracking, hydrogen embrittlement in some steels
Mostly compression, low tension Stiffness, strength in compression Cast iron, ceramics, hardened steel Hidden tension from assembly, bending, or misalignment
High temperature or wear priority Temperature capability, hardness, wear resistance PEEK, hardened tool steel, ceramics Trading toughness for hardness, validate with real tests
For detailed material comparisons, see our CNC machining materials guide.
Manufacturing and post-processing considerations
Manufacturing choices can raise—or reduce—crack risk. The usual culprits are vibration, heat, and surface damage.
Testing and inspection
For safety-critical parts, impact loads, cold conditions, or notch-heavy designs, it’s smart to plan on testing.
If you’re sourcing parts through Protolabs Network, inspection is typically part of the process. The Protolabs Network Standard defines how we implement quality assurance, and many orders also receive an additional quality control review.
  • Non-destructive testing (NDT): Visual inspection, dye penetrant, magnetic particle, ultrasonic testing, and radiography/X-ray.
  • Destructive testing: Impact and tensile testing (elongation and reduction of area), plus metallography to confirm microstructure or heat treatment.
Get started with your next project
Need materials that won't crack when it counts?Upload your CAD file to get an instant quote on parts that can handle the pressure.
What makes a material brittle?
A material is brittle when it can’t deform much before cracking, so it fractures with little warning.
Can ductile materials become brittle?
Yes, many materials lose toughness in the cold, under impact loading, or after environmental damage like corrosion or hydrogen exposure.
What’s the difference between brittle and ductile fracture?
Brittle fractures are fast and fairly flat, while ductile fractures show visible deformation and a rough, torn surface.
What are common brittle engineering materials?
Glass, ceramics, cast iron, and hardened tool steels are common examples, and some plastics also get brittle in the cold or after UV/heat aging.
Can brittle materials be used safely in structures?
Often, yes—if the design keeps them mostly in compression, avoids stress concentrations, and you validate the part with appropriate safety factors, testing, and inspection (per your relevant codes/standards).
brass copper0
What is brass? These are the properties, grades and uses.
Example of a smooth machined part in titanium
What is titanium?
blint rivets steel
6. FDM 3D Printing
Bronze material cnc machining
brass copper0
Learn what brass is, its key properties, common grades and applications, how it compares with bronze, and how brass parts are machined.
What is titanium?
Learn what makes titanium unique, from its strength-to-weight ratio to common grades, uses and how titanium parts are machined and 3D printed.
blint rivets steel
6. FDM 3D Printing
