CNC machining service West Virginia
Online CNC machining in West Virginia
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in West Virginia
CNC Turning in West Virginia
CNC surface finishing in West Virginia
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Our quote builder interface for instant 3D printing service online
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Materials
Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T651 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6082-T651 | 3.2315 | 64430 | AlSi1MgMn Aluminum 6060 | 3.3206 | AlMgSi Aluminum 5052 | EN AW-5052 | 3.3523 | AlMg2,5 Aluminum 2017A | 3.1325 | 24530 | AlCu4MgSi Aluminum 2014 | 3.1255 | 24345 | AlCu4SiMg Aluminum 6063 | EN AW-6063 | 62400| AlMg0,7Si Aluminum 7050 | EN AW-7050 | 3.4144| AlZn6CuMgZr Aluminum 2024-T351 | 3.1355 | 24530 | AlCu4Mg1 Aluminum MIC6 Aluminum 7075-T6 | 3.4365 | 76528 | AlZn5,5MgCu Aluminum 5083-H111 | 3.3547 | 54300| AlMg4.5Mn0.7 Aluminum 6082 | 3.2315 | 64430| AlSi1MgMn Aluminum 6061-T6 | 3.3211| 65028| AlMg1SiCu Show all alloys
Materials
Mild steel
Materials
Brass
Materials
Copper
Materials
Alloy steel
Materials
Tool steel
Materials
Materials
Inconel
Materials
Invar 36
Materials
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 305 customers are satisfied with our CNC Machining service.
David Morar, Canton
“Very good part.”
Moxuan Li, Columbus
“Part looked fantastic”
Cory Kunkel, Mentor
“My parts were perfect!”
Andrew Stowell, Hagerstown
“Great price, good quality.”
Andrew Priest, Apex
“Good job overall”
“Great”
Adam Latour, Toronto
Ultem 1000, CNC machining
Mark Rose, Conway
Yuriy Mirochnik, Huntigdon Valley
David Reinhardt, Monmouth Junction
Dragan Vukovic, Smyrna
ABS, CNC machining
Michael Keenan, Yaphank
“parts looked great”
WILLIAM MEREDITH, Ottawa
Brass C360, CNC machining
Kyle Janny, Lake Mills
Eugene Degre, Worcester
“The part was flawless.”
Kris Steward, Cordova
David Brownell, Medfield
Jamison Go, Burlington
Aluminum 7075, CNC machining
“Absolutely perfect!”
Bobby Watts, Winter Garden
“Good job.”
Eric Gauthier, Trois-Rivieres
“Form, fit and function are as intended. Quick turn around time.”
Joshua Lind, North Liberty
“Quick turn around - Quality precision - Above my expectations”
Chris Szente, Oxford
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
Why choose Protolabs CNC machining
We use automation to make custom machining easier, faster and more affordable than traditional machine shops:
  • We have an incredibly broad range of capabilities - much more than most individual shops.
  • Our quotes are generated instantly - request as many quotes as you like without feeling guilty.
  • No limits on order size - we can scale with you from one-off prototypes to millions of production parts.
  • We leverage market forces within our network to guarantee competitive pricing on every order.
We machine rapid prototypes and low-volume production orders for customers in multiple industries: aerospace, automotive, defense, electronics, hardware startups, industrial automation, machinery, manufacturing, medical devices, oil & gas and robotics.
CNC 101 - hero image 3
CNC machining design guide | Protolabs Network (formerly Hubs)
What is CNC machining and how does it work? This overview explains the basic principles and fundamental mechanics, along with the key benefits and limitations, of this subtractive manufacturing process.
Optimize your part design and material selection to get the most from CNC machining. Read these 14 CNC machining design tips to reduce costs and deliver parts that meet engineering requirements.
How do you prepare technical drawings for CNC machining and why are they important? Technical drawings are standard documents used in manufacturing to communicate technical requirements between the designer, engineering team, and the manufacturer. Clear drawings reduce ambiguity, speed up production, and help ensure parts are produced to the required specifications.
What surface finishes are available for CNC machining? Post-processing and surface finishes improve surface roughness, visual appearance, and wear resistance of metal parts. This guide covers the most common surface finishes for CNC-machined metal parts and how to choose the right one for engineered components.
When it comes to custom part production, choosing between 3D printing and CNC machining can be challenging. This guide breaks down the key differences between these popular manufacturing technologies, helping you decide which is best suited for prototyping, low-volume production, or functional end-use parts.
  • 25+ plastics & 35+ colors
Need corrosion protection without adding bulk? Request a free, instant quote and upload your CAD for real‑time pricing on your CNC part.
