CNC machining service New Mexico
Online CNC machining in New Mexico
CNC milling
  • 3-, 4- & 5-axis milling
See our CNC milling services
See our CNC turning services
CNC Milling in New Mexico
CNC Turning in New Mexico
CNC surface finishing in New Mexico
As machined surface finish
Fine machining surface finish
polishing
Brushed surface finish
Powder coated surface finish
Black oxide surface finish
Brushed + Electropolished
Instant, online CNC quotes
Mild steel
Mild steel
Brass
Brass
Copper
Copper
Alloy steel
Alloy steel
Tool steel
Tool steel
Inconel
Inconel
Invar 36
Invar 36
Alloys
Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 7075-T7351 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6061-T651 | 3.3211 | 65028 | AlMg1SiCu Aluminum 7075-T651 | 3.4365 | 76528 | AlZn5.5MgCu Aluminum 6082-T651 | 3.2315 | 64430 | AlSi1MgMn Aluminum 6060 | 3.3206 | AlMgSi Aluminum 5052 | EN AW-5052 | 3.3523 | AlMg2,5 Aluminum 2017A | 3.1325 | 24530 | AlCu4MgSi Aluminum 2014 | 3.1255 | 24345 | AlCu4SiMg Aluminum 6063 | EN AW-6063 | 62400| AlMg0,7Si Aluminum 7050 | EN AW-7050 | 3.4144| AlZn6CuMgZr Aluminum 2024-T351 | 3.1355 | 24530 | AlCu4Mg1 Aluminum MIC6 Aluminum 7075-T6 | 3.4365 | 76528 | AlZn5,5MgCu Aluminum 5083-H111 | 3.3547 | 54300| AlMg4.5Mn0.7 Aluminum 6082 | 3.2315 | 64430| AlSi1MgMn Aluminum 6061-T6 | 3.3211| 65028| AlMg1SiCu Show all alloys
Alloys
Mild steel
Alloys
Brass
Alloys
Copper
Alloys
Alloy steel
Alloys
Tool steel
Alloys
Alloys
Inconel
Alloys
Invar 36
Alloys
Invar 36
Nylon
Nylon
PPSU
PPSU
Polycarbonate
Polycarbonate
Polyethylene
Polyethylene
PVC
PVC
Polypropylene
Polypropylene
G-10
G-10
PEI
PEI
Nylon
PPSU
Polycarbonate
Polyethylene
PVC
Polypropylene
G-10
PEI
Over 265 customers are satisfied with our CNC Machining service.
“Great price”
Brandon Sweeney, Pflugerville
“Fit, finish and function are perfect.”
Dennis Brady, Waxahachie
“Awesome quality awesome speed time frame”
Jason Millard, RAPID CITY
Aluminum 6082, CNC machining
“Accurate and affordable”
Jason Millard, rapid city
Brass C360, CNC machining
“Amazing quality for the price”
Alloy steel 4340, CNC machining
“we are very impressed and working on an order for 100 more pieces in Sept. thank you!!”
James Ellenwood, RAPID CITY
“great quality”
jamie Ellenwood, RAPID CITY
“love your service and parts”
Jamie Ellenwood, Rapit City
“Amazing quality for a great price”
“Done right in a timely fashion”
“came out perfect”
timi adeyemi, san diego
“Parts were perfect. Delivery was prompt. Great experience.”
Leonard Haberman, Cypress
Alloy steel 4140, CNC machining
“They were really good! I’d strive to make it cheaper though.”
Emin Vartanians, Pasadena
“Parts were made quickly and to specifications. Great speed and value.”
Jamu Alford, Venice
Teflon, CNC machining
“Good parts as expected”
Pratheen Barthiban, Waverly
“All parts were received, and the assemblies went together with no issues so far. I have no complaints!”
Kelly Williams, Benecia
“Form, fit and function are as intended. Quick turn around time.”
Joshua Lind, North Liberty
“The part was flawless.”
Kris Steward, Cordova
“The only mistakes were mine.”
Steven Garvey, Bella Vista
“Excellent. Could not be happier. Exceptional work.”
DANIEL CLARKE, Calgary
“I like how they were able to quickly sourced my parts at good rate and followed up with manfacture to ensure quality of the parts.”
Majed Affan, Calgary
“The quality of the parts matched my expectations.”
Igor Ganakovsky, Calgary
Aluminum 7075, CNC machining
Kyle Janny, Lake Mills
“Everything was done perfectly.”
James Mattson, Portland
Rapid prototyping
  • Instant quotes
  • Instant DFM feedback
  • Live delivery tracking
Production
How we compare
CNC 101 - hero image 3
CNC machining design guide | Protolabs Network (formerly Hubs)
What is CNC machining and how does it work? This overview explains the basic principles and fundamental mechanics, along with the key benefits and limitations, of this subtractive manufacturing process.
Optimize your part design and material selection to get the most from CNC machining. Read these 14 CNC machining design tips to reduce costs and deliver parts that meet engineering requirements.
How do you prepare technical drawings for CNC machining and why are they important? Technical drawings are standard documents used in manufacturing to communicate technical requirements between the designer, engineering team, and the manufacturer. Clear drawings reduce ambiguity, speed up production, and help ensure parts are produced to the required specifications.
What surface finishes are available for CNC machining? Post-processing and surface finishes improve surface roughness, visual appearance, and wear resistance of metal parts. This guide covers the most common surface finishes for CNC-machined metal parts and how to choose the right one for engineered components.
When it comes to custom part production, choosing between 3D printing and CNC machining can be challenging. This guide breaks down the key differences between these popular manufacturing technologies, helping you decide which is best suited for prototyping, low-volume production, or functional end-use parts.
  • 25+ plastics & 35+ colors
Need corrosion protection without adding bulk? Request a free, instant quote and upload your CAD for real‑time pricing on your CNC part.
