Healthcare has many unique constraints and demands when it comes to material selection, where sheet metal can be the material to choose in many of these cases.
If an MRI is the application, stainless steel and aluminum which are not affected by strong magnetic fields could be the material of choice. High precision tools can be made from sheet metal such as intricate surgery tools and scalpels. An added benefit is some of these materials are chemically inert for the human body and can be easily cleaned and sterilized.
The name is a bit misleading. Stainless steel is not stain-proof, and it is far from invincible. It can pit in chloride environments, crack under sustained stress and break down under the wrong conditions. What it does exceptionally well, though, is resist corrosion.
Its mix of toughness, formability and corrosion resistance has made stainless steel the backbone of modern infrastructure. It shows up across CNC machining, sheet metal fabrication and metal 3D printing, in applications from surgical implants to offshore platforms. The downside is that it machines more slowly than aluminum and usually costs more than carbon steel, so choosing the right grade is what makes that extra performance worth paying for.
This guide breaks down stainless steel’s key characteristics, explains its five families and helps you to select the right grade.
The passive layer
Stainless steel gets its corrosion resistance from chromium. To qualify as stainless, the alloy has to contain at least 10.5% chromium by weight. When that chromium reacts with oxygen, it forms a microscopically thin layer of chromium oxide on the surface.
This passive layer is invisible, only a few nanometers thick and is remarkably effective. It blocks further oxidation and helps to prevent rust from taking hold. It is also self-healing, so if the surface is scratched or machined, the layer reforms as long as oxygen is present.
That passive layer is what gives stainless steel its corrosion resistance. Most engineering grades contain more than the minimum chromium requirement, and many also add nickel or molybdenum to improve ductility, stability and resistance to chlorides and pitting. Every grade is a different balance of these elements, tuned for a specific set of conditions.
Categorizing the five families of stainless steel
Stainless steels are grouped by their crystalline structure, i.e., the way their atoms are arranged internally. This structure helps determine properties like magnetism, corrosion resistance, strength and formability.
  • Austenitic (300 series): Non-magnetic, highly corrosion-resistant and easy to form and weld.
  • Ferritic (400 series): Magnetic, with lower corrosion resistance than austenitics but good resistance to stress corrosion cracking.
  • Martensitic: Higher-carbon grades that can be hardened by heat treatment for high strength and hardness. Often used for knives, blades and other wear-resistant parts.
  • Duplex: A roughly 50/50 mix of austenitic and ferritic structure, combining high strength with excellent resistance to seawater, chlorides and chemical exposure.
Family Structure Magnetic Key Trait Representative Grades
Austenitic Face-centered cubic No Best corrosion resistance, most formable 304, 316, 303, 301
Ferritic Body-centered cubic Yes Resistant to stress corrosion cracking, lower cost 430
Martensitic Body-centered tetragonal Yes Hardenable, high wear resistance 420
Duplex Austenitic + ferritic mix Yes High strength, superior chloride resistance 2205
Precipitation hardening Martensitic or semi-austenitic Yes Ultra-high strength via aging 17-4 PH, 15-5 PH
Grade 304 vs. grade 316: which should you choose?
Most of the time, 304 is the standard choice. It offers good corrosion resistance, solid performance and a lower cost which makes it a practical option for general-purpose parts used in mild environments.
If the part will face chlorides, saltwater, harsh cleaning chemicals or marine conditions, 316 is often worth the added expense. Its molybdenum content gives it better protection against pitting and corrosion in more aggressive environments.
If the part will be welded, consider 304L or 316L. Their lower carbon content helps to maintain corrosion resistance around the weld zone.
  • Welded part? → Go with 304L or 316L
Mechanical properties
Stainless steel combines strength, toughness and ductility which shapes how it behaves during production. It forms and welds well, but it is generally slower to machine than aluminum or carbon steel. Austenitic grades such as 304 and 316 can also work-harden during machining, which affects tool wear, speeds and feeds. In practice, that means grade selection, tooling and process parameters all play a role in part quality and cost.
Grade Family UTS (MPa) Yield (MPa) Elongation (%) Key Characteristic Common Applications
304 Austenitic 520–600 210–250 43–45 Best all-rounder, highly formable Food processing, general hardware, enclosures
316 Austenitic 480–600 170–230 38–55 Superior chloride and chemical resistance Marine, medical, pharmaceutical
303 Austenitic 580–700 205–350 40–50 Fastest machining austenitic grade High-volume turned parts, fittings
301 Austenitic 510–590 200–230 35–46 High work-hardening rate, good springback Springs, clips, structural components
430 Ferritic 450–500 200–280 20–24 Lower cost, good SCC resistance Appliances, automotive trim
420 Martensitic 485–750 275–380 15–20 Hardenable for edge retention and wear Blades, surgical instruments, valves
2205 Duplex 620–700 425–500 14–28 Highest strength, seawater resistant Offshore, chemical processing
17-4 PH PH 790–1200 520–860 3–16 Ultra-high strength via aging Aerospace, high-load structural
15-5 PH PH 890–1200 590–890 7–16 Better toughness than 17-4 Aerospace, defense, precision parts
The wide ranges for PH grades reflect different heat treatment conditions: annealed values sit at the low end, while peak-aged (H900) values sit at the high end.
Surface finishes
Polished stainless steel catches the eye, but a surface finish does more than add shine. The right finish can boost durability, make parts easier to clean or help them perform better in their working environments.
Passivation is one of the most common choices for stainless steel. It removes free iron from the surface and helps to strengthen the protective oxide layer without changing the part's appearance.
In terms of hygiene, electropolishing smooths the surface at a microscopic level, reducing contaminants and improving cleanability. For a more uniform matte look, bead blasting helps hide machining marks. Check out our full range of surface finishing services for more options.
Example of surface finishes for CNC milling
The green metal: sustainability and recyclability
Stainless steel is 100% recyclable without losing quality, so it can be remelted and reused again and again. In 2026, most new stainless steel also contains roughly 60-80% recycled scrap, helping make it a cornerstone of the circular economy.
Its long service life adds to that advantage. A stainless steel part that lasts for decades in a corrosive environment can replace multiple carbon steel parts over the same period, reducing material use and waste. For engineers balancing performance with environmental impact, stainless steel offers a practical mix of durability and recyclability, both central to sustainable manufacturing.
Get a quote
Ready to manufacture your stainless steel part? Upload your CAD file for a free, instant quote.
Is stainless steel always non-magnetic?
No. Austenitic grades such as the 300 series are generally non-magnetic, while ferritic, martensitic, duplex and precipitation-hardening grades are magnetic.
Can stainless steel rust in contact with plain steel?
Yes. Contact with carbon steel can leave iron particles on the surface, which can lead to localized rusting. That is one reason passivation is often used after fabrication.
What is the difference between A2 and A4 fasteners?
A2 and A4 describe the stainless steel grade used in the fastener, not its size or shape. A2 fasteners are usually made from 304 stainless steel, while A4 fasteners are usually made from 316. In practice, A2 is the standard choice for general indoor or mild outdoor use, while A4 is preferred for marine, chloride-rich or chemical environments.
What is the difference between 304 and 316 stainless steel?
304 is the standard choice for general-purpose use, while 316 offers better resistance to chlorides, chemicals and marine exposure because it contains molybdenum, which helps it to hold up in harsher environments.
Can stainless steel be welded?
Yes. Many stainless steel grades weld well, especially austenitic grades such as 304 and 316. For welded parts, low-carbon grades like 304L and 316L are often used because they help maintain corrosion resistance around the weld zone.
blint rivets steel
6. FDM 3D Printing
Bronze material cnc machining
Aluminum block
blint rivets steel
6. FDM 3D Printing
Aluminum block
