Manufacturing with Polyacetal vs. Delrin
Polyacetal vs. Delrin: How to choose the right POM plastic for manufacturing
Great parts start with the right material and when it comes to precision plastics, polyacetal (POM) and Delrin are at the top of the game. Both are types of polyoxymethylene, an engineering-grade thermoplastic known for its strength, stiffness, and low friction. They’re commonly used in CNC machining and injection molding because they hold tight tolerances and produce smooth surface finishes. They’re rarely used in 3D printing due to high shrinkage and warping, which make them difficult to print reliably.
The base polymer, POM, was studied as early as the 1920s, but it wasn’t until the 1950s that DuPont developed a new version using end-capping technology. By chemically sealing off the reactive ends of the polymer chains, DuPont made it stable enough to machine, mold, and actually use in the real world. That material was called Delrin and in 1960 it became the first commercially successful homopolymer POM.
Delrin quickly gained popularity as a lightweight, low-friction alternative to metal. In the years that followed, other manufacturers developed copolymer versions of POM that offered better thermal and chemical stability, expanding the material’s use across industries.
While Delrin and other POM copolymers are often used in similar ways, the subtle differences between them can have a big impact on performance and cost. This guide will look at the similarities, differences and when to use each.
Properties of polyacetal
Polyacetal is a strong, low-friction plastic used when you need durability without adding weight. It’s great for when you need your parts to stay dimensionally stable over time.
Common characteristics of polyacetal
  • High tensile strength (typically around 60 MPa)
  • Low moisture absorption
  • Good chemical resistance
  • Low coefficient of friction
  • High dimensional stability
Polyacetal is available in copolymer and homopolymer forms. The forms refer to the different types of monomers used. Monomers are small molecules that link together to form the plastic. Homopolymers (like Delrin) use just one type, while copolymers use two or more for better chemical and thermal resistance. Delrin is the most well-known homopolymer.
Uses and applications of polyacetal
Polyacetal is used when durability and ease of machining are more important than top-end mechanical strength.
Advantages and disadvantages of polyacetal
Polyacetal is a strong, low-friction plastic that’s easy to machine and holds up well under moderate loads, but it breaks down under UV, high heat, or long-term stress.
Advantages
  • Strong, rigid, and dimensionally stable
  • Low friction and good wear resistance
  • Easy to machine cleanly
  • Handles impact and fatigue fairly well
Disadvantages
  • Not UV-stable unless modified
  • Degrades in high heat or acidic environments
  • Weaker creep resistance compared to Delrin
Properties of Delrin
Delrin is a homopolymer version of polyacetal that cranks up the mechanical performance. It’s often used when parts need to take repeated stress and still hold up. Key properties of Delrin
  • Higher crystallinity for added stiffness and strength
  • Better fatigue resistance
  • Stronger creep resistance under load
  • Usually comes with tight material traceability and quality control
Uses and applications of Delrin
Delrin is chosen for demanding applications where strength, certification, or long-term reliability is essential.
  • Consumer products: Common in zip ties, locking parts, and fasteners that need to click and hold under stress.
Advantages and disadvantages of Delrin
Delrin is a tougher, more fatigue-resistant version of polyacetal. It is great under stress, but more expensive and less chemically stable.
Advantages
  • Stronger and stiffer than copolymer POM
  • Excellent fatigue and creep resistance
  • Easy to source with material certifications
Disadvantages
  • Higher material cost
  • More sensitive to moisture and oxidation
  • Can release formaldehyde if overheated during machining
When to use each in manufacturing
If you need a great all-arounder, you can cheer for POM, but if you need higher fatigue resistance, it is Delrin for the win.
Use polyacetal when:
  • You need an affordable, general-purpose material. Great for printer gears or appliance parts where loads are moderate.
  • Moisture resistance or low friction is key. Think sliding door rollers or plumbing valves.
  • You're producing high volumes of complex parts. Its machinability and stability speed up production.
Use Delrin when:
  • Your part faces repeated mechanical stress. Common in automotive safety components or control gears.
  • You need materials that meet strict regulatory standards. Useful for pump housings or medical enclosures.
  • Your design includes high-load or high-cycling parts. Ideal for robotic joints and hinge assemblies.
Comparison of POM materials
Material Type Tensile strength Creep resistance Fatigue resistance Cost Best for
Acetal Copolymer Copolymer ~60 MPa Moderate Good Lower General-purpose parts with good chemical resistance
Delrin Homopolymer ~70 MPa High Excellent Higher High-strength or certified applications
FDA Acetal Copolymer ~60 MPa Moderate Good Moderate Food- or medical-contact components
ESD Acetal Copolymer ~60 MPa Moderate Good Higher Electronics housings that require static protection
Alternative material options
Not all roads lead to POM plastics. Depending on your priorities—like strength, weight, or cost—other plastics or even metals might get the job done just as well or better.
Where to learn more about materials
Manufacturing with polycarbonate vs. acrylic
Compare two common clear plastics to understand how material choice impacts durability, machining, and aesthetics.
See which plastics perform best with CNC machining and how to pick the right one for your part.
Manufacturing materials overview
Get a full breakdown of engineering materials for prototyping and production, from metals to advanced polymers.
Plastics guide
An overview of commonly used plastics and their properties.
Need a material that holds up under pressure? Upload your CAD file to get a free, instant quote.
Get a quote
Is Delrin stronger than polyacetal?
Yes. Delrin typically has higher tensile strength and better fatigue and creep resistance.
Are Delrin and polyacetal interchangeable?
Sometimes, but not always. Use Delrin when your part has tight performance or certification requirements.
What’s the difference between copolymer and homopolymer POM?
Copolymers offer better chemical and thermal stability. Homopolymers (like Delrin) are stronger and stiffer.
Is Delrin food-safe or medical-grade?
Standard Delrin isn’t certified for food or medical use, but FDA- and medical-grade POM copolymers are available.
How do these materials hold up to moisture and chemicals?
Acetal copolymers generally perform better in wet or chemically aggressive environments, while Delrin may be more sensitive to hydrolysis and oxidation.
CNC machining production order
Materials for high-temperature applications
Sheet metal fabrication guide cover image
Malleability explained: choosing materials for forming processes
copper sheet metal
Manufacturing with copper vs. titanium
Learn about heat-resistant materials for high-temperature applications. Compare metals and high-temp plastics, key properties, and find the right material for your project.
Learn about malleability, why it matters in manufacturing, and how to choose the right material for CNC machining, sheet metal fabrication, and forming.
Learn the differences between polyacetal (POM) and Delrin and when to use each plastic in CNC machining or injection molding.
copper sheet metal
From copper's burnt-orange sheen to titanium's hard-edged reputation for endurance, these metals are as functional as they are distinct. Used in everything from electric vehicles and energy grids to aircraft, implants, and cutting-edge consumer tech, copper and titanium solve very different engineering problems. This guide compares them side by side so you can decide when to prioritize conductivity, corrosion resistance, strength, or cost.
