Plastic Injection molding service
Get reliable, production-ready plastic injection molded parts, from early-stage prototypes to full-scale production. Protolabs Network connects you to vetted manufacturing partners, with engineering support and scalable tooling options.
Get plastic injection molding quote
Plastic injection molding service overview
Plastic injection molding is ideal for: repeatable, cost-effective production of complex thermoplastic parts.
Attribute Details
Best for Medium- to high-volume production
Parts Cosmetic and functional plastic components
Molding Precision molds, complex molds, insert molds, family molds, overmolding molds, single- to multi-cavity molds, and more
Mold Materials Aluminum molds, steel molds
Materials ABS, PC, PP, Nylon, POM, TPU, HDPE, and more
Post-processing Spray painting, pad printing, laser engraving, threaded inserts, machining, and more
Finishing SPI finishes (A1–A3, B1–B3, C1–C3, D1–D3), EDM / VDI textures (VDI 12–45), custom finishes
Part tolerances DIN 16742 or tighter tolerances as specified in your 2D drawings
Quality control Parts inspected according to network quality standards; inspection reports available on request
Tooling ownership Tooling is customer-owned, with ongoing mold maintenance support during production
Industry applications Aerospace, medical, consumer electronics, automotive, and more
Manufacturing with plastic injection molding
Plastic injection molding is a manufacturing process that creates parts by injecting molten plastic into a precision-machined mold. Once cooled, the part is ejected and the cycle repeats, enabling consistent, high-volume production with tight repeatability.
Post-processing services
We offer a range of post-processing options, such as painting and heat-set threaded inserts. You can request specific post-processing in the Custom requirements field when you submit your quote. Examples include:
check icon
Inserts
check icon
Pad Printing
check icon
Painting
check icon
Silk screening
check icon
Ultrasonic welding
check icon
Laser engraving
check icon
UV coating
check icon
Heat staking
check icon
Hot stamping
check icon
Post-mold machining
Mold options
We offer a comprehensive range of tooling options to support different part designs, material requirements, production volumes, and lead-time needs.
Tooling Option Description Typical Applications
Precision Mold Designed for tight tolerances and high-accuracy parts. Medical components, electronics housings, precision mechanical parts
Complex Mold Supports intricate geometries and advanced part designs. Automotive components, consumer electronics, complex enclosures
Insert Mold Molds plastic directly around metal or other components. Threaded inserts, electrical connectors, structural reinforcements
Family Mold Produces multiple different parts in a single mold. Low- to mid-volume production of related part families
Overmolding Mold Molds one material over another for added functionality. Soft-touch grips, seals, ergonomic handles
2K & 3K Mold Enables multi-material or multi-color parts in one cycle. Buttons, multi-color housings, functional assemblies
Multi-Cavity Mold Produces multiple identical parts per cycle. High-volume consumer products, caps, connectors
High-Temperature Mold Built for high-temperature engineering plastics. Aerospace, automotive under-hood parts, industrial components
Expedited Mold Optimized for faster tooling and short lead times. Prototyping, rapid product launches, urgent production needs
Compression Mold Uses compression to shape material within the mold. Large parts, thick-walled components, thermoset applications
Stack Mold Uses multiple parting lines to increase output efficiency. High-volume packaging, thin-walled consumer products
Plastic injection molding surface finishes
Improve part performance and appearance by selecting the right surface finish. Mold and post-processing finishes can enhance cosmetic quality, surface texture, cleanability, and scratch resistance depending on the material and application. We offer the full range of SPI surface finishes, including polished and matte options such as A-1, D-2, and D-3. Additionally, We also support VDI surface finishes for textured surfaces, including options such as VDI 28, VDI 30, and VDI 33.
Injection molding materials
Injection molding uses a huge range of plastics, making it ideal for many applications across nearly every industry. We can source thousands of materials on request. Please contact networksales@protolabs.com for specific material requests.
Explore our injection molding materials
ABS PC PP
Nylon (PA) POM TPU
TPE HDPE LDPE
PMMA PBT HIPS
PPS PEEK PEI
PET LCP PC/ABS
PA GF10–50
Plastic injection molding design guidelines
Plastic injection molding projects typically fall into two classes: prototype/bridge tooling and production tooling. These are common design and part capability guidelines, final specs depend on geometry, material, and tool design.
Metric Prototype / Bridge Tooling Production Tooling
Tolerances DIN 16742 or tighter tolerances as specified in your 2D drawings DIN 16742 or tighter tolerances as specified in your 2D drawings
Draft Angles ≥ 0.5° ≥ 1°
Undercuts Manual / Automatic Automatic
Wall Thickness ≥ 0.8 mm ≥ 0.8 mm
Radii (Fillets) ≥ 0.2 mm ≥ 0.2 mm
Looking for design tips? Moldability-focused design can reduce tooling complexity, shorten lead times, and lower part cost. Learn more in the Protolabs Design Toolkit
Quality and accuracy
We manufacture plastic injection molded parts according to strict manufacturing standards. All parts and processes follow The Protolabs Network Standard to ensure consistent quality and repeatability.
  • Each part is inspected on site by our manufacturing partners in line with our quality guidelines.
  • Inspection reports and additional quality documentation are available on request to support compliance and application-specific requirements.
Specialist industries
We’ve manufactured millions of parts for all sorts of applications, but we’re especially knowledgeable in these areas.
Aerospace & aviation
Aerodynamic parts for aircraft, drones, satellites and rockets with AS 9100 certification.
Read more
Medical Image representing medical industry
Medical
Create custom medical devices and diagnostic equipment to get healthcare innovations into hospitals and homes.
Read more
Consumer electronics Branded image of Formify mouse
Manufacture parts requiring highly cosmetic features for gaming, audio, video and smart home products.
Read more
Robotics & automation Image representing robotics industry
Produce complex robotic systems, end effectors and automated machinery for this innovative industry.
Read more
FAQ's about plastic injection molding service
What are plastic injection molded parts used for?
Plastic injection molded parts are used in automotive, medical, industrial, aerospace, and consumer products due to their consistency, durability, and scalability.
Can you support medical-grade or food-grade plastics?
Yes. Material availability depends on performance and compliance requirements. Share your requirements during quoting to confirm options.
What post-processing can be used for injection molded parts?
Common options include spray painting, printing, laser engraving, plating, machining, inserts, welding, and assembly, with additional advanced finishes available.
How accurate are injection molded parts?
Injection molding can be very repeatable once stabilized. Final tolerances depend on material shrinkage, geometry, tooling design, and quality requirements.
What defects can occur in injection molding?
Typical defects include flash, sink marks, warpage, and weld lines. Design and tooling optimization reduce defect risks.
What does plastic injection molding cost?
There are many factors that determine the cost of injection molding your custom parts. The three main expenses are tooling, materials and production. Find out how to reduce your manufacturing costs in our injection molding guide.
