Hello Everybody
I am having this problem already quite a while and i have still not find a fix for it. I know there are a lot of other treads about this issue in fact a had a tread about almost the same problem 5 months ago but i havent figured this problem out yet. I have made some pictures where you can see 2 prints of a 2 by 2 cm hollow test cube. On the picture you can see also a normal extruded piece of plastic. I am running ABS (but PLA has the same problem) at nozzle temp 230C and bed temp 90C with Repetier host flashed on it and i use olive oil to lubricate the filament. I hear a very soft clicking noise from the extruder stepper but i dont now why because the gears are cleaned and i have adjusted my bed 10 times now with a piece of paper.
I hope you guys may know a fix.
greetings Sieuwe
Hi
i had a similar issue and did all the things you’ve described with absolutely no success. I got so frustrated that I eventually took the extruder module out of the unit.
When I did an inspection of the unit (after completely taking it apart, I found that there was a large build up of melted plastic in and around the unit which I spent time cleaning up properly. What was happening was that the filament was not feeding through the extruder, melting and then gunging up the nozzle parts. I put it back together and it worked perfectly.
Now or I just need to figure out how to heat the bed and get flat prints.
Hope pe this helps. Drop me a line if you need support on taking it apart. It’s not hard to do though.
Hello Cleyton
Thanks for your reaction but i have already taken it apart.
It was a bit dirty of dust but i didn’t have a large build up of melted plastic. Was your buildup inside the metal extruder tube or around?
greetings Sieuwe
Hello, I dont have a computer with me but let me ask you a few qiestions. Is the box suppose to be solid or like a see through kind of cross hatch. If you are asking about the stringy ness of it. The retraction rate or extrusion multiplier may need tweaking. What I can do is send you some pics on here of my settings. You could dial them in and under close supervision see if anything changes. The other thing. Before this started happening what changes did you make. For example did you change filament supplier. Sometimes the strand size varies and causes all sorts of problems. We will solve this. The clicking nouse coming out of the nozzle I noticed isnt a issue. I read that you use olive oil to lubricate your filament. That may cause an issue with the plastic adhesion. I would try not lubricating your filament. Also my heat setup is 235 extruder temp and 95-98 bed temp. Thank you.
No problem. This link might help:
Cleyton, You’ll never get a truly flat print while using a stock DaVinci printer bed. The single pain window glass that is used warps anywhere between 0.002in and 0.010in when cold and worse when hot. Borosilicate glass is better with about a consistent 0.001in from one spot to the next cold and little to no added distortion when heated. As for the extruder issues… if anyone figures out what works please let me know. I bought a replacement extruder head and still am having it stop extruding mid print.
Hello Cliff, I read that your extruder is stopping mid way through. Id take a guess but id say its the connector on the top of the extruder losing connection. What I did was replace my connector with one used for connecting up electricals household grade. Kind regards, William
William If it was the connector I’d be set. I’ve replaced every wire. Rebuilt new wiring harness for every motor, from the mother board to the part. Everything is so finicky fix one small issue and 3 more pop up. About the only original parts are the motors motherboard. New table cause mine cracked, new extruder head cause I was grasping at straws. The extruder head helped a bit but still getting the odd non extrusion issue. After every print I unload my filament, clean the extruder with a high e guitar string (same size as the wire clean out thingy) the guitar string is nice cause I can push through the extruder from the top as well as up from the bottom. Even with all my issues recent and historical my not so little 1.0 is still a work horse. I just got a tevo turantula so I’ll be able to compare it first hand against something else. I wish the next model DaVinci would come with a 30x30x30 print area but I’ll probably just build my own at this point as it all seems pretty straight forward and simple now.
Man I know how you feel. That is an insane bit of work you have done there. Im just stabbing in the dark but could the filament be too thin in certain areas and isnt getting enough pressure on the gear. I had that problem once when I switch to a different supplier. I assume you have tested this out though.
William It is a fair bit of work I’ve put into my machine the upgrade to 22awg from 24-28awg wiring made the biggest difference. Everything is noticeably quieter and more responsive. I’ve tested filament my machine hates maker bot filament although I think that may just be settings I didn’t completely dial in. I found a Canadian supplier a couple hours drive from me that has been my go to for filament. Lately I’ve been noticing the weather is the biggest factor in how my prints are going to go. On a cold day it prints like magic. On a warm or rainy day it jams all over the place. I’m thinking of building a humidor to put my printers in to eliminate weather and ambient humidity issues. When she works she works great and when she doesn’t boy does she ever not work right. Regards Cliff
Ahh man I hope you find what the problem is. Ill try and think of some ideas over time.
tk0084
12
Have you lubricated the pulley for the filament?
What type of filament are you using?
Hello
This just happend out of no where actually. I just wanted to print something after a week and it just did this.
The box should be solid from the outside it issnt supposed to have the holes like in the pictures.
I have this printer for more than a half year or so and i have printed a lot of objects with these settings so i dont think settings should be changed but i would like to give it a try.
I will try not to lubricate the filament but the lubrication makes the filament dust free too.
greetings Sieuwe
Sieuwe, It looks almost as if your steps are slightly out of sync. There was a post I think on the solid forum about DaVinci missing steps. The person ended up working the math and changing the step size to more accurate numbers and not rounding up/down to a whole value in the firmware and he saw great improvement on his prints. Unfortunately I don’t have a link to that post but google DaVinci 1.0 missing steps and see what you find. In the article he lists the new steps figure in a table. The basic issue is say each step is programed 21turns per milimeter the reality is its actually 20.963785932 turns per milimeter (**not real figures.**) so that tiny over shoot or under shoot is causing your layers not to line up properly not so noticeable at .3 resolution but at .2 and .1 it’s even more noticeable and has a huge effect on print quality. I’m not sure of the formula he used and maybe it’s in the post. I’m using repetier and I’ve found that the quickest I can push things and still get decent results is at 60mm/s for perimeters infill and support structure everything else are default values.
It also wouldnt hurt to check your belt tension. All three belts. Especially the short one at the back right of your machine. Too tight and you pull the teeth distance out of whack and too loose abd it can skip teeth. I do have a feel its the fact you lube the filament. You could use a dry sponge to filter the dust. Dust has never been an issue with my printers.
Hi, Abs doesn’t need lube in fact it works worse with it. Pla on the other hand does require a light olive oil or something to help it heat evenly and not stick to the metal parts. Or so I understand don’t us pla personally. As for the dust issue I use a piece of yellow cleaning sponge and a clothes peg wrapped around the filament I have found it makes a bit of difference in the layer adhesion and lessens the tendency to jam. Regards Cliff
Heey
I have tried without lubrication and i had still the same problem. I now have made some videos when printing. I am going to upload them but mine wifi speed is not that great so it will take some time.
I havent noticed any teeth scipping so i think the belt tention is okey.
Greetings Sieuwe
Heey Cliff
I will take a look at that. But i think it is something with the extruder.
Groeten Sieuwe
Heey
Here is a link to the folder that contains the videos. I have a couple but they are still loading.
https://drive.google.com/open?id=0B\_-1MqjJ5VfkZldKQ01nZUJfQWs
Greetings Sieuwe
Cliff,
I may have a link you might have already come across. Print Quality Guide | Simplify3D Software
I hope this helps somehow. Could your drive motor be overheating?
When you said you upgraded the wiring. Did you basically do each wire at a time with the 24-28awg. I have moderate experience when it comes to wiring. I am going to think about doing this upgrade myself.
