I have requested permission to check your video.
I have found a link that might help.
https://www.simplify3d.com/support/print-quality-troubleshooting/#inconsistent-extrusion
If you were to just extrude a line of filament and see if it comes out like the one in the photo, we might be able to narrow down one of many problems you may have.
I have seen your videos and I do think that link I sent you will be able to help you out. Basically we may have narrowed it down to 6 possible issues. Keep in mind once you fix these problems other may arise but fingers crossed the link helps.
Dont hesitate to let me know what you have tried and what solution you are up to. I am curious to know how you go.
heey Will
I checked everything that was on the link you send me. I have not found anything wrong. I guess i need to buy a new extruder?
Greetings Sieuwe
EDIT: I may have found something. I have my filament size 3mm but it is 1.75mm. I will try it tonight.
SOLVED
Hello everybody
The problem is fixed. I had the wrong size filament setting in slic3r. It needed to be 1.75mm but it was 3mm.
thanks everbody for helping.
Greetings Sieuwe
Fantastic to hear. I am glad we could help.
