Hi Folks
The base removes easily from the support, but the raft that connects to the print/model is almost melted to the model/print. You can see how the layer of strings are almost separated with little droplet like formations where it “split”.
I am using the correct profile for Z-ABS and all leveling, maintenance etc is done.
My thoughts are the extruder thermostat is faulty. How do I test it?
or there might by some resistor n can set lower.
It pretty much started when summer came around. Not certain that this is a factor though.
Regards,
CloneMe3D
