Anyone figure out Z axis leveling? I can get marginal prints using a raft with one extruder (the left is a bit challenged, but I will replace the nozzle and tubing and see if that helps), but the two extruders are not on the same Z level, so I cannot print with both simultaneously, and I cannot switch from one to the other without re-leveling the bed. Anyone have any suggestions on fixing this? I see in the utilities there is a script, but I can’t figure out how to use it. Thanks.
Hi @Dov_Szego we’d be able to help with this question much more easily if you let us know what printer you’re using, and what slicing software.
