Does anyone have experience with printing on ABS and HIPS/PVA use for support?
Hey Hans, just a heads up that if you tag your post, the people in the XYZPrinting community for example will be notified. Tagging your posts usually increases the chances of receiving an answer. I’ve added it for you this time. Hope this helps! :slight_smile:
Thank you
I know your post was about a month ago but I have a davinci 2.0a that I’ve flashed with repiter and I print with pva all the time and I don’t use abs though I use pla and just got in petg that I’m going to be trying out after I upgrade the extruder with a new gear I have the stock hotend the only upgrade I have done is mess with the extruder gear because of some slipping problems I was having. But PVA works great just make sure if you use slic3r under I belive the support tab there is a box for soluble filament make sure that is checked or you will have trouble with adhesion. Any other questions please let me know. Brian
Translated with google translator
Thanks for the information but I have only purchased the Zortraz M200
It is not convenient with the support but print quality is very good
The solution would be for me the zortrax Inventureto
