Hello ive got a xyz Priting Nobel 1.0, the printer dont print correctly. It only prints the Bottom on the Aluminium plate, the rest wont be printed. In most cases, the print thing lays in the resin tank as a plate. I dont understand this. Hope so much you can help me. Thank you much
Do you use support for your object?
Is that their newest model?
I had three of those printers.
Yours sounds like it is not printing to the print bed. The print bed has to be at the depth where the laser is focused.
Other than that, I would think that the laser has been moved or the mirrors have been moved causing the laser to be out of focus.
Try calibrating the printer again.
RDS2
@RDS2
hello,
thank you much. I tried the horizontal calibration abaut 50times, it wont print. Could it be that the Resintank with the silicone is not ok?
@appie21
yes i use support to the models, ive tried with support and without
