Da vinci 1.0a with repetier. The x axis jitters all over the place. When u jiggle the wires on the right it makes a clicking noise sometimes. After jiggling them sometimes it works for awhile. Right now nothing I do is working.
You have failed/failing wire(s). If the problem is where the wires connect inside the motor housing, you will probably need new motors(unless you are comfortable disassembling the motor). You want to have the wires secured a few cm away from the housing so there is never any tension/movement on the part of the wires that go into the motor.
If the issue is elsewhere in the wire(this is normal wear, a wire can only bend so many times) then you just have to solder some new wires. Make sure you use the proper size wiring. In the future, you want to look into some method of guiding the wires on moving parts so that the bend is evenly spread out. This can have a huge impact on how often these kinds of failures occur.
-Jesse
