MurphM
Hi, I just got an Qidi Tech and am doing some prints. I have a few that work well (still figuring out program to slice in but using GPX to transfer gcode files to SD card) but a lot of the things I’m trying to print, right before printing starts, the bed lowers and the extruder drips plastic wildly down until I cancel the job. I’m sure it’s a simple thing, but what am I doing wrong?
That is probably an issue with the start script or lack of one.
What slicer are you using?
I suggest short of buying S3D that you go find Flashprint. It will work ok. Set the printer as a creator pro. It will output the x3g for you to SD.
MurphM
I just switched to FlashPrint and the print went well! Thanks for the heads up!
