Would my Marvin make the cut? Actually I am not to impressed with it. I think I will have to try again.
Printed on Anet A6
0.4 nozzle
0.1 layer height
PLA
Hot End 200C
Bed 60C
Print speed 15mm/s
Looks good. Some tips would be to see if you can get the bed temp lower after the first layer - reducing heat on Marvin.
Try printing 4 at a time. This helps with cooling.
You might speed up a little. I did him at 1200mm/min I think but it’s a trial to see what works best. To slow can cause heat issues also.
Thanks Wirlyburd, will try that. I appreciate the advice
