I’m pretty new to 3d printing. I have the monoprice maker select v2. It worked fine for the first four prints. Now no matter what I do the pla won’t extrude straight. If by some chance it does stick after a few passes the base curls up and the print head pulls the print off the plate. Here’s video I shot of pla curling out of my extruder. - YouTube Doesn’t lay down on the build plate whatsoever regardless if i apply glue stick, blue tape, or leave it plain. I’ve tried varying my print speed from 200 degrees in 5 degree increments all the way down to 185 degrees. I’ve also tried lowering the plate temp to 50 degrees. I saw that curling may be caused by a clogged extruder so I cleaned the tip with a paper towel at preheat temp and even tried an atomic pull. After an atomic pull the material seems to come out straight but then after the very first time I wipe off excess it begins curling again. Ive even tried different filament and no change still the same problem. I’m so frustrated right now and don’t know what to do. Please help!
