lisaH
Hi I was looking to print a map something like this link below, https://www.instagram.com/p/BAH5r\_NhBSY/?taken-by=roomporn any recommendations?
CusPro
We have a large format SLA machine which can handle a size of 24"x24" . We could print the map in 2 or 3 sections in very high detail.
I assume that you do not have the STL file of this. If you want we could create it for you and print. At this point it is difficult to estimate, We generally charge for the volume of the material. If I had to estimate I would say that this project would cost you up to $2K. please drop me an email if this is within your budget. Here is the adress: info@customprototypes.ca
CusPro
Lisa,
To make your World map even more attractive we can add the geography (mountains, rivers, lakes etc) Please advice what you think.
Hey guys, thanks for the detailed input! Moving forward, please share a link to your Hub page as well. It’s fairly easy for people to contact you via the Contact this Hub button
Cheers
MB3D
6
You could make this fairly easy by using a lasercutter to cut the map out of real wood, then you would also have the wood fibre pattern included.
