I bought a DQ542MA stepper motor driver in order to run my nema 23 High torque motor and I’m unsure of how to properly wire it. I’ve drawn up two different plans so far but I’m unsure of which is correct. Attached is a blank picture if you feel I should draw different connections instead. I have an 8 pin wire connection that will be taking the place of the old motor driver and will be plugged into the motherboard. Any and all feedback will be appreciated thank you.
