hello out there, need to replicate a windmill blade, I bought this windmill from a gentleman who was quite talented in metal work, I do not possess those skills, looking for some help to get started 3d metal printing looks right for my situation
MB3D
Hi there! I assume you are in need for 3d modeling and 3d printing since the 3d model most likely doesn’t exist at the moment. Could you upload pictures of the blade and give rough measurements to tell, what print size you need? Is the strength of metal needed or should the final part just look like metal? What is the smallest level of detail of the model? Any additional information that you can share will help to find the right hub, printer, material and such. Kind regards, Marius Breuer
I have an stl uploaded , so I guess exact copy can be made, original part is aluminum metal, like to stick with that, if possible. is plastic cheaper? can u print off pictures? this is just the first part, have a main frame to copy just looking at prices to see if feasible to reproduce, thanks
