Hey this is Brendon and i cant PRINT the Marvin test print. i got the da vinci 1.0A.
can you tell me what speed(mm/s) and other settings. also some tips because i tried the 1 in each corner and that didn’t work.
*Fixed it and its working all good
If you want to become a hub, you should probably take the time to learn more about 3d printing before doing so. Your customers are going to have things that are much harder to print than marvin, and they won’t be able to tell you what settings you need for the printer. I would suggest to start downloading and printing a bunch of models so you get an idea of what effects speed, temperature, flow rate and so on have on the prints.
To help you get started in the right direction though, it looks like you may need to turn on the cooling fan if your printer has it, and perhaps even lower the extrusion temp by 5-10c.
No one can help you. Your question not only displays a total lack of interest and effort, it expects someone to guess what your problem is and then solve it for you.
Hey @KasaTech, on top of @3DFlying’s solid advice, I suggest browsing the XYZprinting community as well, to see how other users did it. For example, you can find some good advices in this thread here: Talk Manufacturing | Hubs
Hope this helps.
