I am having a problem uploading my STL file to 3D hubs, the object itself is only 68mm high I have confirmed this with an STL viewer and the programmer who created the file. However when I upload it to 3D hubs it says the object is massive causing the price of printing to be over $300 and not compatible with any 3D printers. How do I correct this?
Probably a export dimension error. Exported as cm instead of mm, for instance. 10x dimensions = 80x volume. If you don’t find out why this is happening, just scale it down to 10% and all should be well.
I will look into this and get back to you as soon as possible. Can you shoot me an email with the order number? My email is alex@3dhubs.com
