Hello everyone,
So I have invested whole night to sort this problem out with no luck.
The problem,
When I start the print either through USB or through Memory card the printer goes to x and y end stop fine, then it becomes very slow I mean really really slow, its takes ages to complete one step, then, works fine for about few minutes pausing in between then repeats this process randomly.
Although all the motors and everything else seems to works fine when not printing, for eg. pre printing routine like auto level, manual moving, extruding etc. But its only when starts printing this is the problem I am facing. I have no idea what causing this so will appreciate any help.
Perry_1
What type of printer do you have?
Is this a new problem, has the printer worked in the past, etc.?
What software?
Hi, thanks for the reply.
I am using a prusa i3 assembled model.
Slicing through Cura new version (also tried the older version) and slicr3r. Then used memory card and also usb through repetier similar results.
This is first time i have encountered this problem since 4 months i have using it.
