Niko52
I installed my clay extruder today following the manual WASP provided and using files WASP included for LDM printing. I also followed the guidelines for the pressure needed. When I select the file to print the delta puts itself in place, gets ready to print, and then stops. The auger inside does less than half a rotation and the whole thing freezes. The screen displays the message “Endstops hit: Y” or “Endstops hit X”. I have tried going through the process from start to finish many times and even used files that I sliced myself using CURA and I get the same results. The auger will not spin to push clay out and the whole apparatus does not move. Does anyone have experience with this?
Hello Niko,
I am currently having a similar issue. Have you tried to figure this problem out? I recently purchased this machine. Every time I try to print, it stops and I get a “change filament” error with a beeping noise, while I am using an LDM kit and there is no filament. I have followed the settings in the manual and Wasp videos regarding turning on the Clay Mode and readjusting the Z value. Please share.
