Niko52
Hi, WASP has a video on youtube that shows how to instal the clay extruder. It demonstrates that you can simply pull off and disconnect the green rubber cables. My cables are securely attached with zip ties. Am I supposed to clip these? And, do I need to zip tie them on again if I print with filament?
Yes you have to cut the zip ties and then put It again if you want. Now i’m printing in filamento without the zip ties and It work well
Hi. Of course you must cut the zip ties. On 2040 I work without zip ties… NOT on bigger delta!!!
