hi everyone. i just got my hands on my printer 2 days ago and am on my 5th print. i was just wondering what kind of maintance/upkeep i sould perform every print or every couple of prints. i just want to make sure i get the most quality/time out of this cool machine. thanks
Level your bed each print.
clean printing surface with alcohol
use lithium grease on Z axis rods
keep belts tight
run some cleaning filament every filament change
check all your stop files prior to printing using Netfabb or program of your liking.
cut straight tip on filament prior to loading
tighten any loose bolts
design a calibration box so you can test your printer for accuracy
print a Benchy and measure for accuracy
if a print comes out bad use reference prints from S3d. To fix your issues
always save your printing profiles that work.
many more you will come up with along the way
Wow thanks for all the info. I have been checking the print bed for level every print to far. The other info is super helpful thanks
You welcome.
checkout Wanhao Duplicator i3 tips and tricks. Lots of useful info and videos. It’s a great printer and provides great quality prints.
Any help you need just keep posting, someone will always help
Yeah my first print was garbage. I got the printer used and the calibration went a little wacky in transport bit after I tool the time to calibrate it my second print looks amazing. Thanks for the information.
