Hey Guys, I have a flash-forge Creator Rro and do prints over night. When the printer finishes in the middle of the night it is idle. The flashforge creator pro lights stay on after a print finishes. Is there something I can add to the G-Code in simplify 3D to turn off the lights after the print completes? Thanks.
cobnut
I would suggest asking on the S3D forums. I can also try the suggestion of cobnut later today if you don’t get a solution.
Test this into your ending script.
M146 r255 g255 b255 ; Turn lights off
or M355 ;
Either of those should do it.
M146 is generally used to control humidity but I believe Flashforge uses it for light control.
Chris
cobnut
M355 didn’t work for me on a quick test, so maybe M146 is the way to go as Chris suggests…
I believe you can use an M146 at the end of your gcode. Add it to scripts in s3d.
M146 r0 g0 b0
If I recall, you can also disable LEDs with the front panel, but not sure about that.
