Does anybody know where I can find design specs for the various hardware parts of the Wanhao Duplicator I3? Specifically, I would like to redesign the plate that goes under the build plate and build one.(Perhaps print it)…
Is the Wanhao design open source, or is it not? If so, please let me know where I can find the design specs.
Thanks a bunch !!
If you email me at L.Woinson95@gmail.Com I am currently putting an order together to cut some out of 4mm aluminium
OKay well there are some other designs out there
mostly making it thicker or for some reason 4 bearings vs 3
buy what I really came here to say
is pleease don’t try to print one
the aluminum as it is warps from heat
a print would be destroyed within a print or 2
While you’re doing this might as well increase your build volume with this from Thingiverse. It has all the parts listed
Let us know how it turns out if you do it.
Brian
