Hi All, have taken delivery of the above. Specs are 4 printer heads with a build volume of 470mm x 435mm x 690mm; simultaneous printing of 4 identical objects (can be in different colours & material); seemingly 10 times faster (than what, I’m not sure); .05mm minimum layer height; .00125mm in Z direction (up & down); and .00625mm in X & Y directions (left, right, back & forward).
Plan was to locate in my office in St Leonards and rent out use to those more in the 3D customer space and who need periodic access/use to undertake larger print jobs for clients.
Am exploring options. Let’s communicate if there’s interest. Kerry 0498 888 333
Bay3D
Hi Kerry,
Was thinking about getting The Beast for larger prints we run through our hub. Whats your thoughts on it so far? Did you build it yourself or buy it assembled? If DIY, how technical did you find it?
cheers,
Andy
