Hi everybody, I have a problem I can’t solve…
Dunno why but I can’t get the support material stick to the model. I mean not on the printing bed (the support on the printing bed sticks quite fine) but on the model itself. I have set support to “everywhere” as I need it for the higher floor of the 3d model. Tried many things like lowering printing speed and setting the “z bottom distance” even to 0.0 but nothing… Somebody with same problem who solved it?!
I have a Prusa I3 mk2 and use Cura
Can you decrease the offset for your supports? In S3d you can. I believe in cura there is a z offset for supports. This offset is the distance between your support and the model when printed. Too large, and your supports will not stick to you model. Too little, and your model will fuse to your supports.
