First off my name is Jose and Ima new to this community, what’s up to everyone, I joined this community to learn and share information as I go, I was wondering if any one can help me with my current issue or rather misunderstanding
My issue is that my print outs that are exported to x3g from an stl file via Marker Robot software are very very small compared to what is originally made in software Sketchup. By any chance is there a way I can verify that the object that will be printed out is correct.
ps. Converting the Skp file to an stl is done by me using the plug in “make printable” in the sketchup app.
thanks is advance
Use the STL export plugin for Sketchup. Make pritable is for checking, which is also good.
https://extensions.sketchup.com/en/content/sketchup-stl
You are probably modeling in inches and the slicer thinks it is mm. When you export the model to STL make sure to select mm as the unit of measure or remember to change it in the slicer.
