All I need is this shape with a 2mm wall thickness, no infill, support as needed. WanhoMaker slices it with too much overhang and the print fails. I’ve tried changing the Overhang Angle from default 60 deg to 0 to 90 to 20 all to no avail. PLEASE PLEASE HELP thank you
standard_claw.stl (1.64 MB)
Hello!
I had a look at your file and it seems that it was a bit broken. Have a look at the attached file and see if that works better.
Best regards
Oscar Svensson
standard_claw_repaired_repaired.stl (1.71 MB)
WHAT THE FUCK DID YOU DO???
IT WORKS
Could you let me know in what way it was broken? You don’t even have to answer that, my unbounded joy is forever. You’re a bloody genius.
The problem was that it had some self intersecting surfaces (not to uncommon with STL files). I simply ran the file through netfabb and 30 seconds later it was fixed.
