Hi Everyone I won a 3D printer in a contest and looking to make it a Bargain for someone!
Brand New CEL Robox 3D Printer Asking $1,000, Retails $1,499
CEL Robox 3D Printer Robox is a 3D printer that combines the best next-generation features at a fraction of the cost. Designed totally from scratch with performance in mind, it’s an exciting and much-anticipated model. But it’s not just hype - CEL has delivered a truly stunning product at an equally attractive price point. Precision Creating objects that are accurate to the software model requires extremely precise motion and the highest resolution possible.
All Robox motors and axes are attached to a single stainless steel frame which is a reference surface for all motion; this is rigidly attached to injection molded parts which form the body of the printer to create a super-stable platform. Additionally, the Robox boasts a surreal 20 micron maximum layer resolution, allowing for the smallest details to be created flawlessly. The nozzle valve system created by CEL cuts off filament completely, eliminating ooze and contributing to a much smoother surface finish - meaning less time spent on finishing work. Forward-Focused CEL uses powerful custom-designed stepper motors in the Robox, meaning that your printer won’t become obsolete just because there’s an updated head available - the motors are equipped to handle it.
SPECIFICATIONS: Print Technology; Fused Filament Fabrication (FFF); Build Volume: 210x150x100mm/8.3x5.9x3.9in; Best Layer Resolution; 20 microns; Filament Diameter; 1.75mm+/-0.05mm; Nozzle Diameters; 0.3mm (0.012") and 0.8mm (0.031"); Material Compatibility; PLA, ABS, HIPS, Nylon, PC, PVA; Internal Lighting; Full RGB; Print Bed: Tapeless Heated Polyetherimide; Power Requirements; 100-240VAC, 50-60Hz; connectivity USB 2.0.
Hey Jason just checking to see if the CEL Robox that you won is still for sale? If so please let me know. Thanks
