I have a CTC printer with dual extruder. I have installed sailfish 7.7 and it mostly seems fine. I am using slicer and when I print and it finishes normally everything seems OK. But when I cancel a print, the head starts to clear the build place and either crashed into the left side or the plate is being pulled down and motors keep grinding. This seems wrong but I am at a loss as to how to stop this. Any suggestions welcome. :slight_smile:
Apart from this it is a great printer.
Thanks
Neil
OK, after more research I have found that this only happens when the left extruder is used as the main extruder.
Using the right extruder seems fine.
Hope this helps someone :slight_smile:
What model of printer do you have?
On your printer do a Eeprom reset in the utilities. Choice the 3rd choice Erase Eeprom. It will say it may make your printer inoperable but I had the same problem with mine when updating and it solved that issue. It retains your last firmware settings that you need to cleared.
Yes that worked! Thank you, I thought an EEPROM reset would leave me with no settings.
I have a CTC dual extruder. Replicator 1 or FlashForge clone.
