hello. i want to buy a 3d printer with this
Desired characteristics:
- 2 extruders - printing size app. 25x25x30 cm - heated bedb - closed frame - resolution around 20 microns - price around 3,000 USD
i saw on aliexpress some models. what can you recommend?
tnx
Lulzbot TAZ 5, Ultimaker 2 extended, BigBox dual and leapfrog Creatr (HS) would be closest to your needs, at least those are the ones I know, I’m sure that there are more printers out there that you should take into consideration. Cheers, Marius Breuer
Hello, I suggest looking into the Createbot Max, it has dual extruders available, heated bed included, an enclosed case, print size is 28 x 25 x 40 cm and has a optional touch screen and comes in 4 colors. Available on www.3dcreator.ca starting at $2199.
