Hi guys I have problems with a ramps 1.4 Prusa i3 3D printer. I have been printing for months until the arduino went and I reflashed the new board with marlin (latest) and the motors only go in one direction and the homing on the z doesn’t stop it from going down. I don’t know the problem is but want to start printing again. Any help would be appreciated.
zx81
Did you configure marlin? You will need to set up your bed temp sensor, your hot end sensor, end stops (normally open/ normally closed?!), Homing direction, X Y and Z steps per mm, Z speed (default was almost always too fast). Then you will be ready to print.
It seems to just go one may and makes high pitch noises and stay in one place and the numbers don’t go into the negatives like they use too. How could I change this in the software?
