Hey guys.
I have been reading up on 3d printers because I came about one at about $300 and it surprised me you could get them this cheap, which means I could potentially afford one! Yay!
The thing is, I would want it with the highest precision, as previous extrusion-based prints i have seen have kind of disappointed me.
My use would be for making molds for food and candy and small figurines (I’m a 3D modeler by profession)
I like tinkering around, but if I get a 3d printer it is mostly to get results.
So I am not sure how this goes, I guess minimum thickness is determined by nozzle diameter, minimum precision is a question of how well calibrated mechanics are (more than what motors are in) and minimum layer thickness mostly comes down to material control, amount of overhang on subject and most importantly, how well the bed has been leveled.
For the Prusa models I have been looking at it seems to be something like:
XY precision is not much of a problem.
Wall thickness comes down to nozzle used where the agreed upon standard is 0.4mm.
Layer thickness is usually rated at 0.1mm as pretty standard, while 0.05mm is the “premium”.
The last one I have really only seen on the Original Prusa i3 mk2.
So the question is, if I want precision, should I opt for the expensive new Prusa, or can I also achieve it with a cheap half-the-price prusa “clone” and a bit of tweaking and tinkering?
Also, definitely feel free to send me to some article on this matter.
I just have not found anything that really explained it to me.
Thanks!
