Hey Guys,
have a Flashforge Creator Pro and want to use PVA and PLA. I am also using Simplify 3D. I want to print pieces that need the PVA but I cannot get anything to stick. The PVA does not stick to the bed. Anu suggestions or settings. I am using a heated bed with PLA and PVA and it will not stick.
Enza3D
Lay down a layer of glue from a glue stick (Elmer’s kind or similar works fine) and see if that helps. Elmer’s glue basically is just PVA, so by laying down a layer of this, it helps the PVA stick in the same way abs/acetone slurry helps ABS parts stick
