I need some help with my new Maker Select V2 and I figured this community would be able to help me out. The Maker Select V2 doesn’t reach the right lengths on the Y Axis. When I push (or have it move) the bed all the way to one side, the extruder goes over the edge, and when I push the bed all the way to the other side, it doesn’t make it all the way. When I print something in the center, it prints offset up high. When I print something that is a bit bigger, it goes over the edge and continues to push out the PLA even though there is no bed under it. I have had trouble with my bed earlier. The end stop for the bed wasn’t getting triggered, the bed was too high. I eventually just raised the stop up. When I take it off, it has room to go all the way. My one problem is, how do I make sure it is centered, and how will I place the end stop, as there is no holes for it on the end. Please help, this is ruining all of my prints. A side note to this, when I received my printer it was a bit different than others that I saw coming out of the box. The screws for leveling the bed did not have wing nuts, they had thumb screws already. (It was a mod that I was going to do so Im not complaining.) and the adhesive cover for the bed was different than other people’s. I don’t know if this is important or not. Please help.
ducky
Sounds like there’s still a problem with the bed endstop. Can you confirm if homing works correctly on to the corner of the bed?
if yes, can you attach a picture of the bed end stop and the bed?
