Hi It’s the first thread that I writ it on this forum and also I’m new in the 3D printer world. I came here hopping to get some help from you.
I have a 3D printer Kossel 2020 that I bought it on January and till now I didn’t print anything with it, because my friend and I got a lot of problem with it and each time when we fix something , another one shows up . All the problems that we get is from the program. Our printer use Mega 2560 motherboard.
We have 2 problems, the first one we don’t know how to program the servo ,we followed the guide, but we see that it’s not clear, how does it work? I need a clear explanation about the programming of the servo, also my friend told me, wires can also a possibility of not working. When I put the G code on the Pronterface software,I see that the servo turn and it works perfectly ,but how can we program it so if we need to print something it should be working automatically??
The second problem, since we didn’t know the problem of the servo, we skipped it ,so it was the last setup as the PDF guide shows us, I decided to print something ,I putted the design in the slicer software to convert it to G codes, after doing that, I added the G codes (of the design) on Pronterface software to print it. And since we have PLA , I heated the bed at 60C and the temperature of the nozzel at 185C , when they got at these temperatures, I clicked print to start printing , but nothing happened. The temperature of the nozzel stopped a 185C (but still working) and the temperature of the bed continue increasing more and more , from 60 to 74C , but I didn’t understand why it’s not printing. Even the mini machine that takes the filament didn’t start, so what is the problem???
And the program that we are using is the Arduino, Btw the computer recognized the temperature clearly ,but still didn’t work, I disconnected and shut it down ,but didn’t work, so what is the problem??? Thank you so much for the help
