my temp in the extruder is not working properly. you can see it is set at 210degrees but the actual temp varies around 131degrees
what kind of extruder are you using?
i MAY HAVE FOUND THE PROBLEM. The thermistor was out of it"s hole. I will know if that was the problem later
