O.k. I’ve found the magic combination for me. The first is that my bottom and top layers were set to way too thin. The default settings I was using was creating a host of issues for me. For some reason the QIDI software slicer was set to 2.25 mm for filament size. Not sure if this would cause an issue, but the max size is 1.75mm. My top and bottom layers were way wrong. And incapable of creating the support I needed. The hover instructions indicate for high quality bottom layer should be set to.06 mm. For lower quality as high as .25mm. For the models I was printing, the detail came out very excellent at .2 mm.
.06 mm created a bunch of issues (like sticking too well or not at all! )
If you’re having issues with sticking or not sticking adjust your print settings, check them and recheck them! Next, my hot plate. I’ve tried a variety of tempts and I seem to get the best stick results around 55 Celsius. I’ve tried down to 40 and I start having issues with something not sticking right and coming home to a blob of plastic… I went up to 60 and down to 55 and that seems about the optimal temp for me. I have a gut feeling that humidity, pressure, and other climate related things may be at play for the optimal hot plate temp.
If I have something that doesn’t stick (which 95% of the time I don’t anymore). I put one smattering of a glue stick layer down and have the printer ready to go before putting the glue down. It dries very fast, so I highly recommend putting the glue on with everything preheated and ready to go.
Lastly, I just replaced my QIDI print plate self adhesive cover. Usually the blue Painters tape like surface was too smooth for it to stick in the past… I tried a print overnight last night, and it stuck just fine and came out even more amazing than before. (No glue residue stuck to the bottom of the pieces.)
In fact, the initial outline of plastic stuck too well, I couldn’t get it off, but all the pieces came off just fine and looked great!
I’ve been printing almost nonstop now for around 3-4 weeks and so far the only mistake prints were my fault. Or that 1 in one hundred of 1 piece not sticking.
The final piece of this is leveling. I found after a power outtage that the leveling was off. Was fine before the outtage, but, it brought the printing plate too high and too close to the nozzle. It was almost digging into the hot plate. There was one other time, it was probably 1/8th of an inch away from the plate, for no apparent reason, and had to adjust then as well.
It may be a good idea to build in a leveling maintenance task once every 2-3 weeks.
Overall I’m very happy with my QIDI 3d printer now that I got the settings and optimal print environment.
