Hey all,
I haven’t used my printrbot simple metal in about two months. Went to start it yesterday and the tip would heat up but when I went to home the machine it would not home and I got this readout:
< start
< echo:Marlin 1.0.0
< echo: Last Updated: Aug 7 2015 01:06:07 | Author: (j-laird, Printrbot firmware)
< Compiled: Aug 7 2015
< echo: Free Memory: 3758 PlannerBufferBytes: 1232
< echo:Stored settings retrieved
< echo:Steps per unit:
< echo: M92 X80.00 Y80.00 Z2020.00 E96.00
< echo:Maximum feedrates (mm/s):
< echo: M203 X125.00 Y125.00 Z5.00 E14.00
< echo:Maximum Acceleration (mm/s2):
< echo: M201 X2000 Y2000 Z30 E10000
< echo:Acceleration: S=acceleration, T=retract acceleration
< echo: M204 S3000.00 T3000.00
< echo:Advanced variables: S=Min feedrate (mm/s), T=Min travel feedrate (mm/s), B=minimum segment time (ms), X=maximum XY jerk (mm/s), Z=maximum Z jerk (mm/s), E=maximum E jerk (mm/s)
< echo: M205 S0.00 T0.00 B20000 X20.00 Z0.40 E5.00
< echo:Home offset (mm):
< echo: M206 X0.00 Y0.00 Z0.00
< echo:PID settings:
< echo: M301 P22.20 I1.08 D114.00
< echo:Min position (mm):
< echo: M210 X0.00 Y0.00 Z0.00
< echo:Max position (mm):
< echo: M211 X152.40 Y152.40 Z152.40
< echo:Bed probe offset (mm):
< echo: M212 X25.00 Y0.00 Z-1.20
< echo:SD init fail
Any ideas why? I have changed computers, cables, and reflashed the board. I get a failure at 0x00002 when using ATFlip on the confirmation of firmware installation.
Thanks All!
It looks like your Slicing Software is out of date or erroring. Your Cura may need to be updated.
I tried both the 4.0.2 and 4.0.2.5 on two separate computers… I will try reinstalling again tonight at home and trying again though. However I do not think this is the issue as when I try to update firmware to the new “simple” or old “revF” hex files neither work all the way through and pass the verification check on Atmel FLip.
Thanks!
No Luck, Still having an “SD Init Fail” as shown on Ponterface
As an update, I heard from Printrbot Support. My board failed the blank check and they have deemed the board dead and in need of replacement. I have had this printer for less then a year and the board has already failed. I have asked for some discount or about a replacement program for boards as this is unacceptable. If you have the same issue, I wish you the best of luck…
