Its the same filament as the other picture, but at 200 micron. has a satin look.
I would use a layer height of .2064 and a base layer height of .254 this is the reccomended layer height using the 3/8 lead screw according to the prusa calculator and printrbot. Also try slowing down your print i had luck printing marvin at 30 mm/s and also adjust your z offset to the hundreth of a mm and use a raft when printing small intricate objects.
fiveangle, thanks for the details here. Have you ever printed Marvin with ABS at 0.1mm?
What settings would you use for ABS?
I assume that your “cooling cylinder” is a second model which you are printing to move the hot end away from the primary print to allow each layer to cool. What retraction settings do you use when doing this?
I have attempted to print Marvin with Yellow PLA and Black ABS on my Printrbot Simple 1403
The PLA print came out nice, but I am still having trouble with ABS.
I have images posted on my hub page:
https://www.3dhubs.com/montgomery/hubs/craig
Thanks
